Let's try this again - Alex's NB
- Vehicle: NA6 - Turbo
Re: Let's try this again - Alex's NB
Nice effort Alex, def a high 12 in there just need a decent launch with a lower 60ft, easier said than done with the mx5. Looking forward to seeing what this thing makes with some more boost
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
- A.Chen89
- Vehicle: NB8B - Turbo
Soooo here's the flip side of owning a turbo MX-5.
Met up with a couple if forum goers for a run at the drags - was good seeing everyone giving it a hit!
First run ran a sloppy 14.1, second run I dumped it from 5500 and bam! Broken driveshaft. Sheared off cleanly into two.
Looks like the Borg is very good at doing it's job.
Better the driveshaft than the gearbox though, hopefully will get it up running again soon.
Anyone got a spare shaft ;)?
Bugger Alex. Hope you get it running soon.
- A.Chen89
Not the end of the world.
On the bright side, found out it weighs ~1160kg with a full tank of petrol, rollbar, power steering, A/C etc. not bad!
- A.Chen89
Bump from the dead.
Sorted out some teething issues and found some time to play cars again. Originally tracked this last October at Circuit Club but had overheating issues with no under tray and a seized sliding pin in a front brake caliper.
Also had a corroding radiator as the result of electrolysis which hopefully I've fixed now.
Went to a Circuit Club track day on Saturday and managed to drive the car trouble free all day! Oil temp gets a bit too high but hopefully some ducting will sort that out.
I installed a beat rush under tray but still haven't closed up the sides so I believe the air is passing through mostly the radiator but not going through the oil cooler. The cooler isn't in the best spot but should be able to make it work - the AC condenser also doesn't help.
And here's a video!
Boost is great, still learning how to drive the thing as my lines weren't clean as before but its a start! I don't think I'll be tracking this in the middle of summer.
And here's a video!
Water-methanol injection Alex! In fact, you can just use it to run distilled water.
- A.Chen89
Hmm haha that seems a bit extreme. I'll probably forget to top the tank up
Nothing wrong with that...just lose some power (it is noticeable though!).
Once I'm finished with the water-meth mix, I'm just going to use distilled water and see how that goes, and just keep water-meth for track days.
- A.Chen89
Thread revival!
Still alive and the car still goes well; albeit after having fixed a couple of oil leaks and putting in a new Kaaz 1.5 way LSD. The Borg still spools strong with its signature kettle boiling sound.
Still have a bit of an issue with oil temps on the track since the cooler is located on the steering rack but working on a solution!
Also had some ducting made up; made a world of difference at Wakefield! Temperature never moved above 90 degrees on the Queen's Birthday public holiday track day.
13422400_859246054208582_568875544756016692_o by Alex Chen, on Flickr
13442479_859248354208352_12126914435947711_o by Alex Chen, on Flickr
Is it me or is every other car massive?
13483055_859246100875244_9015027051126992957_o by Alex Chen, on Flickr
13490604_859246264208561_6355126117511907336_o by Alex Chen, on Flickr
13490730_859242887542232_3762646020957775838_o by Alex Chen, on Flickr
Also did a bit of drivng recently, managed to do Thunderbolts Way and ended up at Walcha. Great drive but the surface was a bit less then desirable in certain sections.
14054403_10153657815440740_2687696765462023738_o by Alex Chen, on Flickr
IMG_8497 by Alex Chen, on Flickr
Here's a couple of shots from a Putty run, check out the variety of cars!
IMG_8990 by Alex Chen, on Flickr
IMG_8991 by Alex Chen, on Flickr
IMG_8992 by Alex Chen, on Flickr
Hopefully looking at doing another day at Marulan sooner or later as well as giving South Circuit another go again.
That's fine looking Integra in those pics!
Nice views on the drive to Walcha. I miss going out on group drives...should get onto it again!
Car is looking fine as usual! Good to see you really getting to use it. I just bought some work wheels, which are polished with Gold centres. Wasnt really sure how it would look on a silver car but just saw your pics again and actually think it will look great!
Sent from my SM-G920I using Tapatalk
Just got to keep them wheels clean!
- A.Chen89
Hehe cheers fellas
Might need to grab some 6UL's apu, then you won't notice!
- bruce
- Vehicle: NA8 - Turbo
Nice setup.
Has the silver coating on the turbo manifold lasted? Does it still look good?
- A.Chen89
Yep the ceramic coating has held up well; still looks the same as the day it got coated
