An MX5 Called M1L3S
Re: An MX5 Called M1L3S
Postby 93_Clubman » Tue Oct 09, 2012 4:38 pm
bruce wrote:If the insurance coy allows it, you may be able to buy the write-off cheap?
But then your car will be listed as a registered write-off...not a big issue for a 'cheap' car.
Bruce, not well known, but in Vic if the vehicle is over 15 years old it won't be listed as a repairable write-off with Vicroads. Had this personally confirmed by Vicroads when I bought a hail damaged unregistered NA. I comprehensively checked the vehicle, replaced the damaged panel, got a RWC, & re-registered it, without even the need for a VIV ($600 or so). However, a VIV is still required for vehicles under 15 years old, & of course Vicroads do still list statutory write-offs regardless of age.
Postby bruce » Tue Oct 09, 2012 5:15 pm
More government legislation to confuse us poor car owners.
Can it get more complicated? (that's a rhetorical question)
91 Malibu
Postby 91 Malibu » Tue Oct 09, 2012 5:40 pm
stilletto_rebel wrote:Just heard from the repairer... car not written off!! :D They're fitting a new roof, centre dash and Pioneer system. I should have the car back Saturday morning. 8)
Great result let me know if you still need to use the hardtop, hopefully I will see you Sunday on GOR run
Cortina MK11 GTL
Mazda 3 SP23 Daily drive
Arty
Postby Arty » Tue Oct 09, 2012 5:52 pm
That's great news mate and OEM parts to boot :P
Hope you make the run on Sunday. :MOCHA_LES:
Postby 93_Clubman » Wed Oct 10, 2012 12:49 pm
That's great news Miles!
stilletto_rebel
Postby stilletto_rebel » Sun Oct 28, 2012 3:18 pm
As the weather looked like it was going to hold, I set about removing the spft-top with the plastic screen and fitting the NB top with the glass screen.
Halfway there!
Most of the rain rail has been removed/destroyed by the wreckers. If water gets in I'll remove it again and fashion one out of duct tape.
All done! I did it all by myself and took a little over two hours. 8)
Visit my garage thread
Postby 93_Clubman » Sat Nov 03, 2012 11:11 am
Good stuff Miles - any luck with the clutch?
stilletto_rebel
Postby stilletto_rebel » Mon Nov 05, 2012 8:55 am
Booked in for Thursday with a local garage I've used before. I was surprised I got home under my own steam last Thursday, so don't feel confident driving too far.
Postby 93_Clubman » Mon Nov 05, 2012 4:25 pm
Damn
stilletto_rebel
Postby stilletto_rebel » Thu Nov 08, 2012 9:12 am
Left the car with the garage this morning. I'm really surprised how quickly this came on - literally overnight! After reading up on this (a little knowledge is a dangerous thing!) I'm wondering if I've just lost a couple of springs on the clutch, throwing it out of whack...?
I'll find out later today, I expect...
stilletto_rebel
Postby stilletto_rebel » Thu Nov 15, 2012 8:59 pm
Collected M1L3S from the garage yesterday evening. Jobs performed:
Remove gearbox, flywheel & clutch.
Supply & fit new rear main oil seal.
Supply & fit 2nd hand flywheel.
Supply & fit new Exedy clutch kit.
Refit gearbox.
Remove LHR hub assembly
Supply & fit new wheel bearing kit.
Unseize LHR brake caliper.
Total cost for all of the above was $1,038.54.
M1L3S is now much smoother and much, much quieter! What I thought was a noisy gas system was actually the wheel bearing! When idling, the car would sometimes stutter. I suspect that was the flywheel issue, as the... thingy (I've forgotten the word!!) in the centre had seized.
The new clutch is awesome! 8)
Postby 93_Clubman » Sat Nov 17, 2012 11:28 am
stilletto_rebel wrote:I suspect that was the flywheel issue, as the... thingy (I've forgotten the word!!) in the centre had seized.
Spigot/pilot bearing by the sound of it.
Good to hear it's sorted - cost sounds reasonable for all those parts & labour.
stilletto_rebel
Postby stilletto_rebel » Sat Nov 24, 2012 2:24 pm
30 degrees in the sun sounds like perfect weather to fit new gear lever boots - NOT! But that's what I did anyway. :roll: I really need a garage or roofed area I can do this sort of work in...
Halfway there - Old boots off:
Not a drop of oil in the gearbox! :shock: (No wonder it sounded clunky):
All done, and new leather gear lever and handbrake gaiters fitted:
Took me half an hour, if that.
I was planning on replacing the corner reflectors with the clear indicator ones I bought off MX5 Parts, but it's just too damn hot! Maybe tonight...
stilletto_rebel
Postby stilletto_rebel » Thu Jan 17, 2013 12:01 pm
Today I got round to replacing the plugs and leads that I bought in December before I flew to the UK. I was having one hell of a time getting the first plug out until I realised that there was something in the well preventing me from gripping the plug. Using my trusty wire coathanger, I managed to pull it out to discover it was the bottom end of the HT lead!
I had the same issue with the #2 plug as well. As I was replacing the HT leads I realised that the old ones I was removing were the original OEM ones fitted at the factory! They have numbers on them and Japanese symbols.
Unsurprisingly, the car runs even better now!
tobias
Postby tobias » Thu Jan 17, 2013 1:57 pm
The numbers on the leads just means that there genuin parts. Means the car must have been serviced at a dealership
Users browsing this forum: No registered users and 176 guests
