DWEEZLE'S BACK!!
- Dweezle
Re: DWEEZLE'S BACK!!
Thanks guys.
Much appreciated.
so annoying.
Thought I was done with this job and then I sort of sat back and realised.
It is not obvious to me anyways why this pedal box sits different.
Guess I will have to try and find another one.
Much appreciated.
so annoying.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- Vehicle: ND - 2
Its not from an automatic or something is it?
compare the busted accelerator pedal to that one, you might get away with bending it over in a vice.
i need to do this sh*t soon and i'm not looking forward to it.
- Dweezle
jorgan92 wrote:Its not from an automatic or something is it?
It would appear not.
Autos have a pretty big brake pedal.
Jace wrote:compare the busted accelerator pedal to that one, you might get away with bending it over in a vice.
Yeah i thought about doing that but am worried it would not work or even just weaken it and i would have to do it all again.
UGHHH
Jeremy Clarkson
Jeremy Clarkson
- Dweezle
Much more preferable
Jeremy Clarkson
Jeremy Clarkson
- zossy1
Looks bent Mark.
They bend fairly easily, and given the battle it is to get them out I would not be surprised if it was bent at some stage during removal...
Lou, you pulled it out I presume, is that possible?
If it was me i'd just bend the sucker into place but I'm a sledgehammer-egg kind of guy ;)
- Dweezle
Thanks ZOSSY!!
I thought of that.
Was just worried i would screw such a nice new looking one up.
Or i would bend it over and it would not be right.
I should be able to bend it in the car right?
I would not have to pull it out again ??
Please.. PRETTY PLEASE say I CAN DO IT IN THE CAR
I thought of that.
Jeremy Clarkson
Jeremy Clarkson
- -alex
A good vinyl wrap will cost you the same as a good respray, much for a much really. I was seriously considering it myself til dad offered to teach me to spray.
I am still contemplating having my bonnet wrapped in black. I'm looking at about $200 for that.
- Dweezle
Your dad doesn't want to Spray mine does he ??
Jeremy Clarkson
Jeremy Clarkson
- geofiz
Dweezle wrote:Thanks ZOSSY!!
I thought of that.
Please.. PRETTY PLEASE say I CAN DO IT IN THE CAR![]()
Mark,
As I put in my PM, you should be able to bend it in the car without to much hassle. use a pipe spanner or similar to get some leverage and you can control where the bend happens.
Good luck and let me know how it goes.
R
NB8A - mostly stock for now
- Mr nanotech
-alex wrote:I am still contemplating having my bonnet wrapped in black
... Isn't it already painted black?
- -alex
Dweezle wrote:Your dad doesn't want to Spray mine does he ??
I think he has moved back to working on his bike now, but some James Squires might change his mind =P
- Dweezle
Had a little time this Arvo.
Tightened the pedal box up and applied a little force to move the accelerator pedal closer to the brake pedal.
Seems to have worked mostly.
It is not 100% but maybe with a little more persuasion it might get there.
I have noticed the pedal is stiff with the cable connected.
Does anyone know if I can just use some motorcycle cable lube to free it up or is a new cable on the cards?
The clutch also has a fair bit of free play before it starts to disengage but I believe I can just adjust that out.
More time with my head under there !!!! Ugh!!
Jeremy Clarkson
Jeremy Clarkson
- Dweezle
Threw a bit of this through!!
Not SUBARU but seemed to do the job.
Removed the bastard LOCKING NUT, so the 18's are off!!
Found a small issue from who ever did the 1.8 install.
The fan shroud is cutting into the 1.6 intake piping.
Not a big deal, i will sort that out easily.
Can anyone tell me what this could be under the passenger side bonnet edge?
Jeremy Clarkson
Jeremy Clarkson
