timk makes up for talent with an EFR
- timk
Re: saboteur's NB
As this is a daily dríven car, I have changed my brake pads over to Carbotech 1521 pads. Hopefully they will be much less dusty and noisy than the XP10/XP8 combo I was running.
- TieNN89
- MINX
Re: saboteur's NB
saboteur wrote:As this is a daily dríven car, I have changed my brake pads over to Carbotech 1521 pads. Hopefully they will be much less dusty and noisy than the XP10/XP8 combo I was running.
The 1521s are ok, they are very clean.
They just feel a bit 'wooden' if you push them hard on a spirited drive.
- timk
Re: saboteur's NB
I think I'll leave the 1521s in the rear and swap to XP10 fronts on track days. I tend to trail brake a bit so a bit less rear bias might be a good thing.
Today is the day! The car has been dropped off to MX-5 Plus (Automotive Plus) to go under the knife:
- zero00
Re: saboteur's NB
saboteur
Under the knife? Like Pauline Hansen said: 'PLEASE EXPLAIN?'
Roger D-SUNSHINE COAST
- timk
- zero00
Re: saboteur's NB
OK thanks!!
You and 'justabitrusty' running Monday?
- jerrah
- timk
Re: saboteur's NB
Went to ChipTorque today and got the ECU modified to suit running in of the new engine:
New engine is very close to having all accessories swapped on and ready to be put back in:
Hopefully we will be firing up the engine on Saturday!
- jerrah
Re: saboteur's NB
SE turbo sits in nice and close to the block.
Very clean and shiny, looking forward to seeing it running!
No COPS / coolant reroute?
1991 MX5
- timk
Re: saboteur's NB
Trying to keep changes to a minimum at the moment, so I may look at the Toyota coils after everything is in and running.
As for the reroute, I'm using an SE head and SE head gasket so it isn't as critical:
http://forum.miata.net/vb/showthread.php?t=350182
- TieNN89
- jerrah
Re: saboteur's NB
That sounds better, I've never been a fan of having the long pipe around to the back.
Very clean installation, I think it will be great!
1991 MX5
- timk
Re: saboteur's NB
Oil return all sorted:
Engine is back in the car as of today, so we are on the home stretch now!
- timk
Re: saboteur's NB
A few finished touches. We used an SE intercooler mounting support and modified it with extra tabs to suit the aftermarket intercooler:
The engine will be started later this afternoon!
Users browsing this forum: No registered users and 244 guests
