Andrew's '93 NA6 - KL V6 swap
Jace
Re: Andrew's '93 NA6
Postby Jace » Sun Oct 30, 2011 10:25 pm
Woah, this swap is going to be droolworthy, I love OEM+ swaps like this one!
Good luck, I'm immensely keen to see it come together!
Beelzeboss
Postby Beelzeboss » Mon Oct 31, 2011 6:08 pm
Thanks Jace!
Well, I just finished what has the be the most difficult part of the swap :lol:; liberating the engine from the MX-6. 1.5 full days on this, finally it's out.
Andrew
NA-6 2.5 KL V6
http://barberprecision.com.au/
Beelzeboss
Postby Beelzeboss » Mon Nov 21, 2011 7:37 pm
Bit of an update. The mx5 engine and gearbox are out and separated. I've got CAD files for the back of the KL engine and for the front of the mx5 gearbox, however the starter motor for the automatic is different from the manual MX6 :evil: I need to get a manual starter motor before I can fabricate the adapter plate.
In the mean time I painted the rocker covers red. I think they look great :D They're not as orange as in the pics, they're definitely red.
Andrew
NA-6 2.5 KL V6
PaulF
Postby PaulF » Tue Nov 22, 2011 1:49 am
Red rocker covers? That's an easy 25kW right there. :mrgreen:
EDIT: Actually, 50kW because there are two!
Beelzeboss
Postby Beelzeboss » Tue Nov 22, 2011 9:42 pm
PaulF wrote:Red rocker covers? That's an easy 25kW right there. :mrgreen:
:lol: Now I just need to paint the calipers for a total of 75kw extra!
Andrew
NA-6 2.5 KL V6
PaulF
Postby PaulF » Tue Nov 22, 2011 11:53 pm
Or just get some of THESE babies! Brembo's for $11.25. 8)
Beelzeboss
Postby Beelzeboss » Thu Dec 08, 2011 2:17 pm
I made a plate to replace the distributor. I'll be running wasted spark and semi sequential injection so I only need a crank trigger. To that end I'm modifying the standard 6 tooth trigger wheel into a 36-1 trigger wheel.
Also my lightweight chromoly flywheel arrived a few days ago.
I've finalised the design for the adapter plate, now I just need to find the best place to buy a big chunk of aluminium. Once the adapter plate is done the build will move pretty quickly (I hope)
Andrew
NA-6 2.5 KL V6
lee
Postby lee » Fri Dec 09, 2011 12:18 am
subscribed, because this looks like it could be fun :D
'91 Roadster
timk
Postby timk » Sun Dec 11, 2011 11:02 pm
Ditto! :beer:
Beelzeboss
Postby Beelzeboss » Thu Dec 15, 2011 8:20 pm
Cheers guys :mrgreen:
I've made good progress on the adapter plate over the last couple of days. All the holes are drilled and tapped, I just need to cut out the shape. The plan is to get the engine in the car on Saturday to measure up the engine mounts. I hope once the engine is mounted in the car progress will be much quicker.
Andrew
NA-6 2.5 KL V6
Hjt
Postby Hjt » Thu Dec 15, 2011 11:49 pm
Nice meeting you the other day Andrew, Hope you made it in time for work!
- Hayden
Beelzeboss
Postby Beelzeboss » Fri Dec 16, 2011 1:22 pm
Thanks Hayden, great to meet you too. Yes I did make it, just. lol.
I made a bit more progress this morning. Good ol' chain drilling, my favourite fabrication technique. NOT!
Then a hacksaw with a wire blade
and then if you're lucky...
And then...
IT FITS THE ENGINE PERFECTLY!!!!!
I'll put up another update tonight, barring any problems this afternoon with the gearbox-adapter plate fitment I should have the engine bolted up to the gearbox!
Andrew
NA-6 2.5 KL V6
Postby Jeo » Fri Dec 16, 2011 2:15 pm
Sick. Quite looking forward to seeing this progress.
Beelzeboss
Postby Beelzeboss » Fri Dec 16, 2011 6:49 pm
:twisted:
IT'S TOGETHER! I'm so relieved it actually went together without too much trouble, that never happens with things I build :lol:
Tomorrow is measuring for engine mounts, and many pictures of the engine sitting in the car :lol:
Andrew
NA-6 2.5 KL V6
timk
Postby timk » Fri Dec 16, 2011 10:19 pm
I hope it's not too tall! Fingers crossed!
