Custard’s Tart
RS2000
Re: Custard’s Tart
Postby RS2000 » Tue Aug 20, 2019 10:54 am
Red_Bullet wrote:190 through the kink then topping out at 210 before braking at Karousell, that's all pretty spectacular. That's some going! 160 around turn 6 onto the straight..well..I give up. :roll: :shock: :shock:
Yes the speeds shown aren't always related to what the car is doing. In the Karousell it goes from 90 to over 160, then back to 115 on exit.
Custardtart
Re: Custard’s Tart
Postby Custardtart » Tue Aug 20, 2019 10:56 am
ozace wrote:NOT re003, no fun at all
Haha :D think my tongue was firmly in my cheek :lol:
NC1 - 2.5 opposite lock device
Lakeside 62.3
ozace
Re: Custard’s Tart
Postby ozace » Tue Aug 20, 2019 11:01 am
I made a very conscious decision to keep my car a roadie with occasional track days. The focus was on making it fun on the road and comfortable.
Little things can make a big difference. I have V720 and rs4 tires for track stuff but they are harsh on the road compared to the pilot sport 4 and are a very noticeable firmness on the road I don't enjoy in the wet. I have had great times with tein suspension and added the edfc to control stiffness automatically based on G forces and speed. It gives a very compliant road ride and firms up enough on the track for me to live with it. My re003's are kept for the occasional drift day
2008 NC 2.5l conversion, Tein edfcpro, 4.1diff and a big smile
Custardtart
Re: Custard’s Tart
Postby Custardtart » Tue Aug 20, 2019 11:04 am
The Garmin Virb camera’s GPS is only 1hz and a bit all over the place. I’ll post a RaceChrono snapshot which is linked to a 10hz external GPS.
Lakeside 62.3
Custardtart
Re: Custard’s Tart
Postby Custardtart » Tue Aug 20, 2019 11:48 am
ozace wrote:I made a very conscious decision to keep my car a roadie with occasional track days. The focus was on making it fun on the road and comfortable.
Do you have any pics of your car? I’d imagine it would be very nice!
Lakeside 62.3
ozace
Re: Custard’s Tart
Postby ozace » Tue Aug 20, 2019 12:21 pm
I don't know how to post pics otherwise I would share
Alanh
Vehicle: NC - LE
Re: Custard’s Tart
Postby Alanh » Fri Aug 23, 2019 10:29 pm
Custardtart wrote:
Alanh wrote:
Custardtart wrote:Apparently the tuner just did an identical 2.5 with the same cams etc. Does anyone know if that owner is on the forum? Would be good to catch up.
Based on your description of the tuner I may be your man. I ran 177.3 rwhp with 2.5 head, Kelford stage 2 cams, 10kg flywheel, full exhaust, 2.0 injectors & running conservative timing advance in case of bad fuel. Tuner reckons there's another 10-15hp in the timing but we went on the safe side as it's mainly for road use.
Apart from cams just swapped everything over from 2.0 - 2.5 & dumped it in.
Another Brisbane 2.5 swapper, welcome on board Alan. Would be good to meet up and have a look at yours. I’m over in Samford Valley but get to cars n coffee most months.
Great power you made, do you know which cams yours were? I had a look on the Kelford site and could only find stage 1 cams. My cams came from Deckspeed and were their 2.5 specific road cam which I was told was a custom Kelford grind.
Which exhaust are you running and any plans for any track days?
I'm in Clontarf so not too far for a catch up. Unfortunately because of work don't get to the cars n coffee but sounds like I might have a couple of "headaches" coming up.
I couldn't find a cam listing when I looked so rang was told they had a set of stage 2 to the Deckspeed specs on the shelf. I'd have to dig out the spec sheet to see if is the same as yours although I suspect they will be. Seems only differences between us is I'm running drop mounts with heavy duty engine mounts and a full GWR exhaust - sport max headers, helmholtz with cat mid pipe & super Q muffler (had to #2 header pipe shortened by 10mm because was hard on the column... ggrrrrr - supposedly for Aus car! Meant had to get ceramic coating done again), I've removed the ERG valve and are running a high flow filter. My engine had done 70K and I thrashed it around for a 1000K before it went on the dyno to make sure the rings were free & sealing properly.
Tarin in Clontarf did my tune (Ecutek) & I'm thinking of going back & loading a 2nd map with the full advance so I can switch between them as required. He was pleased to hear I was using the 2L injectors because the impedance & response time is different to the 2.5L which would have meant more time on dyno & setting up - $$$$$$
Part of the build plan was to do a couple of track days but haven't been able to make it yet. Being a track virgin it's something a need to grow some & try it out. I have enjoyed a couple of "spirited" Sunday club runs so am looking forward to the day I make it.
I read in your later posts that you don't like your clutch pedal. Mine was really low after the change & I can tell you lengthening the pedal pushrod is a PAIN. What I found invaluable was to use a 10mm brake hose spanner (heavy ring spanner with split for pipe).
Daffy
Re: Custard’s Tart
Postby Daffy » Tue Aug 27, 2019 10:48 am
Custardtart wrote:I haven't got round to sorting the gearbox and had a fair bit of crunching from 5th to 4th and 4th to 3rd. I'm still not entirely sure it isn't me adjusting to the different clutch travel following the engine swap. There's no issues when road driving so I'm reluctant to pull the box and do a full strip down at this stage.
I had similar issues a while back after a clutch swap to find there was an issue with the spigot bearing. RE the people who can fix standard seats to take a harness, where abouts are they and how much do the charge mate?
Custardtart
Re: Custard’s Tart
Postby Custardtart » Tue Aug 27, 2019 11:18 am
I’m going to pull the box soon and check everything out. I did fit a new spigot bearing when I did the engine swap but the symptoms are similar. I also have a new set of plastic bushes to fit in the box as well.
I must admit I’m not looking forward to it as I found undoing the top gearbox bolts to be a right pita.
Lakeside 62.3
Custardtart
Re: Custard’s Tart
Postby Custardtart » Wed Aug 28, 2019 12:55 pm
Daffy wrote:RE the people who can fix standard seats to take a harness, where abouts are they and how much do the charge mate?
I’ll dig out their details
Lakeside 62.3
Custardtart
Re: Custard’s Tart
Postby Custardtart » Wed Aug 28, 2019 1:04 pm
Alanh wrote:I'm in Clontarf so not too far for a catch up. Unfortunately because of work don't get to the cars n coffee but sounds like I might have a couple of "headaches" coming up.
I think I’ll go back to Tarin shortly too, now I’m running a free flowing midpipe and muffler it feels like I’ve gain a few extra horses, I’d also like to try and smooth out the low revs but overall I’m really happy with how it turned out. I’ll let you know when I’m planning on being over at Tarin’s so we might catch up.
Re the clutch pedal adjustment thanks for the tip. Ive been upside down under there checking it out and it looks very fiddly!
Lakeside 62.3
Custardtart
Re: Custard’s Tart
Postby Custardtart » Wed Aug 28, 2019 1:06 pm
I’m booked into Lakeside again this coming Saturday for another morning general practice. Looking forward to it muchly! I’m gonna be super busy for a while starting September so it might be the last outing for a while.
Lakeside 62.3
Alanh
Vehicle: NC - LE
Re: Custard’s Tart
Postby Alanh » Wed Aug 28, 2019 8:00 pm
Nothing happening on Saturday morning so might pop into lakeside and catch up
Custardtart
Re: Custard’s Tart
Postby Custardtart » Fri Aug 30, 2019 4:30 pm
Alanh wrote:Nothing happening on Saturday morning so might pop into lakeside and catch up
Might see you there, track time starts at 9.30am.
Lakeside 62.3
Custardtart
Re: Custard’s Tart
Postby Custardtart » Fri Aug 30, 2019 4:33 pm
Beautiful day for a drive up the perfectly named Mt Glorious. Endless curves and not a cop in sight.
Lakeside 62.3
