Mx5, Chapter 2
The American
Re: Mx5, Chapter 2
Postby The American » Wed Nov 06, 2019 5:34 pm
Red_Bullet wrote:I admire your commitment.
:D :NB8B: :NB8B:
The American
Re: Mx5, Chapter 2
Postby The American » Wed Nov 06, 2019 11:34 pm
ManiacLachy wrote:.... I guess this marks the beginning of "Chapter 3" :mrgreen:
:D
The American
Re: Mx5, Chapter 2
Postby The American » Mon Dec 09, 2019 8:54 am
Well, the White Mouse didn’t stay fixed for long.
About 1.5 minutes driving at the Lakeside DTC to be approximate. :-(
Parts Inside the gearbox have been rearranged into non-optimal configuration for the transmission of drive. :DIY:
Custardtart
Re: Mx5, Chapter 2
Postby Custardtart » Mon Dec 09, 2019 11:51 am
The American wrote:Well, the White Mouse didn’t stay fixed for long.
Bug*er!
What were you up to at Lakeside?
NC1 - 2.5 opposite lock device
Lakeside 62.3
The American
Re: Mx5, Chapter 2
Postby The American » Wed Dec 11, 2019 6:00 am
Custardtart wrote:Bug*er!
Last round of the SCMSC’s competition on the DTC track.
I can’t complain, it really has been a hard life for it.
The American
Re: Mx5, Chapter 2
Postby The American » Sun Dec 15, 2019 9:26 pm
Thanks to Mr Wilkins I have a low Km SE 6 speed on the way.
The American
Crunchy no move-y
Postby The American » Tue Dec 17, 2019 8:24 am
Tuba? Thanks Lightyear.
Hopefully my 'later' model Miata Roadster Shifter fits this. Given that SE's were a later NB development, my guess/hope is that it will fit.
Here is the over-exuberant launch and gear change that ended in crunchy noises and no drive from 2nd gear.
greenMachine
Re: Crunchy no move-y
Postby greenMachine » Tue Dec 17, 2019 12:41 pm
The American wrote:Hopefully my 'later' model Miata Roadster Shifter fits this. Given that SE's were a later NB development, my guess/hope is that it will fit.
Mine did 8)
:mrgreen:
The American
Postby The American » Tue Dec 17, 2019 1:44 pm
Mine did 8)
:mrgreen:
Thanks GM - good to know!
rascal
Re: Mx5, Chapter 2
Postby rascal » Wed Dec 18, 2019 6:49 am
Fairly sure the gearshift itself is the same between late/early and 5/6 speed, it’s just the cup/bush on the end that is different.
I somehow ended up with a 5 speed shifter in a 2001 6speed, which (not surprisingly) had a horrible sloppy shift action.
I bought a MR roadster shifter hoping it would fix it, yet was the same sloppiness, just a shorter throw :frown:
A few emails back and forth with Bill from MR and we worked out the cup was different so he sent me a 6 speed cup (all of $14) and it fixed the shift action completely.
RS2000
Re: Mx5, Chapter 2
Postby RS2000 » Wed Dec 18, 2019 9:07 am
The integrated ball on the end of the factory gear lever is also different. The approximate diameters are:
5 speed & early 6 speed levers - 15mm ball with 19mm bush.
Late 6 speed levers - 18mm ball with 22mm bush
MR gear levers have one size integrated ball, with 2 different od bushes to suit.
The American
Re: Mx5, Chapter 2
Postby The American » Wed Dec 18, 2019 11:27 am
Thanks All! :D :DIY:
The American
Re: Mx5, Chapter 2
Postby The American » Sun Jan 05, 2020 10:23 pm
The box ended up being an early NB1 (no Ill intent from seller) which did not fit my shifter, and I didn’t have the bits to make up a small bush shifter. The box’s sensors had the pig tails cut off, and I broke one of mine when swapping it onto the working box. The box also had a toasted rear seal thanks to its firey history, so I was down a shifter, rear seal and a sensor to make this box work.
Magpie offered me one of his spare sensors (thanks!) and someone else contacted me with a brand new sensor they did not need. They also had an NB2 6 speed which unpicked up as well (thanks!)
I have put a new seal in the NB1 box and have the sensors for it now. I will find the missing shifter bits, and will have a spare 6 speed if anyone is looking for one.
Anyway, I put the NB2 gearbox in this afternoon, and subject to a last bolt check, it’s all buttoned up again and ready for mischief.
By far the most time consuming bit was getting a single nut on the exhaust down pipe undone and done up. I even sacrificed a cheap SCA 12mm ring spanner to make a semi-open ring spanner. This should have helped but it turns out the spanner was too cheap and the remainder of the ring wasn’t strong enough to hold shape...
And that’s the end of my Christmas break
Re: Mx5, Chapter 2
Postby Magpie » Mon Jan 06, 2020 8:14 am
The American wrote:Magpie offered me one of his spare sensors (thanks!)
And The American helped out with a spare shifter (small bush) whilst I order the parts to rebuild mine!
The American
Re: Mx5, Chapter 2
Postby The American » Mon Jan 06, 2020 8:05 pm
rascal wrote:Fairly sure the gearshift itself is the same between late/early and 5/6 speed, it’s just the cup/bush on the end that is different.
The factory steel shifter tip and the factory bush are different diameters internal and external. Miata Roadster deal with this by having one tip size for all their shifters, with different bushes to complete the match to the box. Unfortunately the Mazda bushes don’t allow interchange with a simple factory bush swap.
