mrpham's summer build
plohl
Re: mrpham's summer build
Postby plohl » Fri Nov 08, 2013 2:40 pm
I am sorry.... but I lol'd....
Get home without any issues?
plohl
Postby Jeo » Fri Nov 08, 2013 5:59 pm
Not trying to be a dick, genuine question; is the point of lobster welds to look cool?
mrpham
Postby mrpham » Fri Nov 08, 2013 6:08 pm
plohl wrote:I am sorry.... but I lol'd....
We got home around 1AM and I was laughing my ass off too hahahaha
Well didn't really know the exhaust broke until we got home :P the car wasn't louder or sounded much different...
Jeo wrote:Not trying to be a dick, genuine question; is the point of lobster welds to look cool?
Personally I like it, total welding porn (when it's shiny).
Current Forum Specials!
Gladiator
Postby Gladiator » Fri Nov 08, 2013 6:56 pm
What? Didn't sound any different? Must have been maxed out on loudness already.
mitch_f1
Postby mitch_f1 » Fri Nov 08, 2013 7:14 pm
Question, do you have a flex joint in your exhaust at all?
mrpham
Postby mrpham » Fri Nov 08, 2013 7:35 pm
mitch_f1 wrote:Question, do you have a flex joint in your exhaust at all?
There is a flex joint just before the cat converter. I guess similar arrangement to the factory system?
Postby hks_kansei » Fri Nov 08, 2013 9:24 pm
I think back in the day it was also used instead of mandrel bends when people didn't have the equipment to do mandrel bends.
Mr nanotech
Postby Mr nanotech » Sat Nov 09, 2013 2:09 am
^ Correcto
mrpham
Postby mrpham » Fri Jan 17, 2014 11:42 pm
Valve Clearances - http://omgpham.com/valve-clearance
Long time no post!
This has been a long over-due service item, valve clearances. Because it's a brand new head build, the clearances have to be checked roughly at the 5000km mark.
This forum thread below was very helpful.
http://www.miataforumz.com/how-40/how-check-valve-clearance-re-shimming-nb-head-331/
But I was too lazy to pull everything apart to remove the camshafts, so I ordered the Mazda special service tool for this :D It basically let's you remove the shims with camshafts still in.
Mazda part number is 49T0-12-0A0A.
Using my feeler gauge to measure all the clearances first, best to record everything as well. A couple of simple calculations are done to find what shims are required to get the clearances within spec.
Tool bolted in and setup.
Bucket pushed down, shim out so it could be checked and measured. This one is 4.00mm.
mrpham
Postby mrpham » Mon May 26, 2014 9:15 pm
Radio Delete - http://omgpham.com/radio-delete
Been wanting to do this post for awhile now. It's been a combination of research and a lot of testing to get to this point. Quite pleased with the outcome but would like to make some changes later on, more on that later.
A few goals I had for this project:
  • Delete radio/head-unit.
  • Keep everything as simple as possible, think minimal.
  • Nexus 7 tablet to display all the Megasquirt gauges via Bluetooth.
  • GPS with offline maps, pause/resume music on power off/on, wired tether to phone.
  • Maintain charge with full brightness, GPS, music and gauges running.
  • Easy to remove tablet from the car, one cable to dock.
  • Amplifier install that is compact yet has tone controls (bass/treble).
  • To make it possible for the tablet to dock with just the one cable (USB), and not have to plug the headphone/Auxilary cable in as well, I had to use the tablet's USB OTG Host feature. This basically allows you to plug heaps of USB devices to your Android device, keyboards, mice, thumb-drives, USB DAC, etc...
However, while in OTG Host mode Android doesn't allow the tablet to be charged at the same time. This is where the software comes in to make it all possible. Check out Timur's website for details on his custom built ROM. It is optimised for car installs and enables charging while in USB OTG Host mode, deep sleep mode when power loss is detected (huge power saver), and hot-plugging of audio devices.
You will also need a USB OTG Y-Split cable, I picked up mine off eBay for not much money. While you're there you'll also need a USB DAC, again very little money for these. The USB DAC basically plugs into the tablet via USB and outputs sound for the amplifier.
We're very lucky with Megasquirt when it comes to Android software. MSDroid allows tuning as well as gauges, still in the beta with a new major release soon. ShadowDash is by the same creators as TunerStudio and is a lot more stable but only allows gauges and no tuning features.
http://omgpham.com/msdroid
http://omgpham.com/bluetooth-x-megasquirt
For amplification, I decided to go the DIY route. This consists of a pre-amp so that I could have bass and treble control. For the power-amp stage I picked a DIY kit that is built around a IC chip that is commonly used in car radio.
Took me literally under ten minutes to build the power-amp, pre-amp took a bit longer. I than stuffed them both into a plastic case with the USB DAC. The case was picked up from JayCar.
Sound wise, this combo worked very well. The pre-amp gave me plenty of tone adjustments and power-amp was able to keep up with the volume levels I usually listen at. But it did suffer from a pop noise on power up, and I may have blown the IC chip because of insufficient heat-sinking!
So the other option I'm look at is this little amplifier, Pyle PLMRMP1B. It's very compact, plenty of power, remote gain control and anti-thump turn on. I'll re-use my current DIY pre-amp though, need those tone controls!
My initial install of the tablet wasn't very successful. Couldn't use my hazard/retractor buttons without removing the tablet, very flimsy, and blocked both centre vents.
I than found a company called ProClip that produce a Nexus 7 holder that was perfect for my requirements.
I used a custom made radio panel and made it a complete blank. This would allow me to hard mount the ProClip tablet holder. Very happy with the qualilty from the holder, sturdy and easy to dock/undock from the car.
For the wiring part, I used new connectors. 4-way connector for the outputs to the speakers, and a 3-way connector for ground, accessory and constant 12V power.
Photos of the finished project!
Parts list:
Postby Lokiel » Mon May 26, 2014 9:39 pm
How's readability of the tablet?
Others have reported that this is is a big issue and resorted to fashioning a shroud to try and improve it.
My PLX Devices DM-100 multi-gauge has an LCD screen, it's mounted in the cluster's water temperature gauge location and is hard to read when the sun is at my back.
mrpham
Postby mrpham » Mon May 26, 2014 9:47 pm
Lokiel wrote:How's readability of the tablet?
In certain lighting conditions the glare is quite bad, but I don't find it to be a huge problem. It would be be really bad with the top down though. I put on a anti-glare screen protector and it has helped.
DanZig
Postby DanZig » Tue May 27, 2014 1:00 am
Fantastic work! Looks brilliant!
gslender
Postby gslender » Tue May 27, 2014 1:15 pm
Would it be possible for you to offer a bundle or kit of this? Would be interested.
Sent from my iPad using Tapatalk HD
mrpham
Postby mrpham » Sun Jun 01, 2014 10:59 pm
gslender wrote:Would it be possible for you to offer a bundle or kit of this? Would be interested.
Hey mate.
I could help with organising that, but still playing around with the amplifier choices. The DIY kit worked well but I killed it because my heatsink wasn't big enough. I've ordered that Pyle amp from the US, will see how that goes.
