NitroDann's Long Awaited Garage Thread
- mrpham
Re: NitroDann's Long Awaited Garage Thread
Nice work!
Also love the discussion on the log manifolds, it's something I wanted to build my self when I go FI and glad to know that they work well for our application (under 300hp). Was thinking of using the standard SR20 turbos as they come up for sale cheap and often.
With this sort of setup, is it worth getting the manifold ceramic coated?
Current Forum Specials!
- NitroDann
That IS a used (though GCG rebuilt) SR20 turbo.
As for ceramic coating, it makes it rustproof, and helps a lot with engine bay heat control. Though I doubt you will get a noticeable performance improvement on this manifold.
When are you looking at doing it Pham?
- mrpham
Not too sure yet, sometime this year though. Also want to get my ITB build on the way soon and have some more track time with that while I slowly collect parts and tools (mainly a welder), too busy these days to rush any thing.
Might have a chance to pick up a cheap BP engine, so not sure what to do about that yet either...
Starting to miss turbo engines
- NitroDann
Cheap BP? Easy as.
As for the welder, either buy a good one like mine, or hire a mig, tack the manifold and have someone who is good weld it up.
- NitroDann
Quick build update.
Ive decided against using a braided stainless oil feed line.
For a few reasons.
As dweezle found out, getting a universal one and a multitude of fittings sucks. The hose will never be the right length either.
Braided hoses suck, actually, non oem flexible hoses suck. They flop around, end up ziptied everywhere, and braided ones slowly saw your car in half.
This is the reason I use a TIG welded hardpipe for all reroutes, not the regular floppy universal water hose. Its strong, lasts forever, stays put on its own and looks professional.
So heres the oil feed line.
Not as exciting looking as 4 feet of coiled up braid, and anodized fittings everywhere, but this is how Mitsubishi chooses to feed Evos, how Ferrari chose to feed the F50... etc etc. I think you get it. The pipe will be bent into place when its fitted onto the car.
It looks oem, it works oem, it has oem reliability, and supports itself like oem. Win, win, win, win- in my book.
For a few reasons.
- Dweezle
I like that!
I assume there would be no issue with flex as the engine and turbo can not move independently??
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- NitroDann
Correct.
Edit: In the above post I meant F40.
You're a bitch man! Just like some other guy I know here tempting me with a CF seat...just makes me want to go out and spend money.
...must...resist!
...must...resist!
- Sean
Solid pipe is tidy!
- gslender
How ya doing the return then?
- Vehicle: ND - 2
Solid work Dan, real credit to you (just read most of your build thread)
- NitroDann
Braided stainless. Theres nothing near the return, and as its a thick vertical hose it doesnt need supporting, SS drains are never an issue.
- wozzah1975
Looking good mate
Woz
Woz
- NitroDann
And some more...
Thoughts, questions?
Still to do..
Fit cat to exhaust, finish dump pipe, air filter..
Thats about it.
Edit: At this rate, someone might actually buy this engine
Still to do..
Thats about it.
- Vehicle: NA6 - Turbo
Looks good dan, haw close are you to the firewall where the hard line exits the engine?
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
