BEAVIS' White Track Car
- rossint
Re: BEAVIS' White Track Car
I've just been through this and I'm glad I didn't go soft and get 8s. Still running my 205 NT01s which fit surprisingly well, only a little stretch. I'll get 225s when these tyres are dead. If it's just for the track get 9s, 6ULs fit well on my NA and any rubbing you may get will come down to tyre size and offset rather than the extra inch in the wheel.
I'm running 205/50's on 15 x 7 and still have lots more time to find!
However to go to 225's in AD08R's I need to go to 16 or 17" rims or I could get a set of 15 x 8 and see how these go.
20170121-DSC_0540 by Eipeip, on Flickr
- beavis
- Vehicle: NB8B - Turbo
Magpie, certainly sounds like your laptimes are being hindered due to tyre and wheel size. But, given WTAC rules, it's totally understandable.
Stupid rules.
No, onto....... Painting Doors
The doors on this car were hand me downers, very rough and I'd previously painted them with rattle cans in a mismatched white.
Since I'd gone to the effort of painting the roof, it didn't seem like much more work to get the doors painted too.
Well, that was until I got a little closer to them.
One door in particular was really battered up, dents and wrinkles and layers of paint that just made me cry. I sanded away the old flaked and poorly adhered paint and prepped them for a fresh coat.
My el-cheapo paint gun I bought for under $100. Actually worked alright for a super budget job. (and ghetto paint booth behind)
After filling the bad bits, the doors got a couple of coats of primer and the odd bit of filler again to neaten up the areas that needed more attention.... then, some paint went down.
The colour came out nicer than it did on the fastback, I think I've gotten better with the painting method and working with the settings on the paint gun.
This is a bit of a 'money shot'. I think this shot perhaps flatters my success with the paint more I deserve. But it does look nice and shiny here. Oooooohhh
You can see the beginnings of a run in the corner of the door handle.
- beavis
Oh I should mention, I took some video of a friends car recently. A turbo NA6 with a collection of both interesting and unusual mods.
First time I've done a more artsy video like this really... so apologies in advance for my lack of video making skill, I tried to polish a turd (the turd being my poor recording skills) by doing the best I could via post processing in Adobe Premiere.
I liked the na6 video.
Any chance that you have some under bonnet footage and also some sound of it pulling hard?
Thanks for sharing.
Thanks for sharing.
I was next to this on the parade lap at fan fest, very cool. TE37's are timeless and always a winner
- beavis
speed wrote:Any chance that you have some under bonnet footage and also some sound of it pulling hard?
Sadly no I failed in that regard....
All good. I was just looking for further inspiration to see if there was anything else I should be doing
- SKYHI
Good effort with the video. I like the style, but also think some engine shots and some in car footage with sound or a static video of it pulling away or a drive by would have added something to it.
- SKYHI
Good effort with the video. I like the style, but also think some engine shots and some in car footage with sound, or a static video of it pulling away or a drive by would have added something to it.
- beavis
Soo... onto some of the other things that I had managed to finish (or in some cases, half finish) before the MX-5 Fan Fest event I mentioned a few posts ago.....
Oil Cooler
First up, the oil cooler has been moved to a better spot, plenty of airflow here - although it's clearly not yet plumbed in.
On the pondering list is, exactly what sort of lines I will run, and where/how I till run them. Need to prepare the wallet first, hose fittings aren't cheap.
Rad Duct
And with the oil cooler in place, I needed to work out the front duct work between the bumper and the radiator(s).
This is a reasonably simple aluminium box which bolts to the front of the car and is almost a perfect seal around the radiator, and also seals on the bumper opening.
This angle kinda helps to visualize the airflow.... in the front, through the heat exchangers, out the vented hood.
Brake Duct
Aluminium brake duct mockup version 1. I'm not sure if these will stay as is, and whether I will leave them as aluminium. Still pondering that one.
I guess you can liken them to home made singular motorsport items. On the to do list is to run a hose of some form to them, and make an inlet in the front ductwork.
Front bumper
Lastly, the front bumper has been cleaned up and painted... The difference between the before and after is quite satisfying.
Here it is looking very sad for itself after I separated it away from the old splitter.
It got a good share of body filler and sanding around the front.
And after a good clean, removing a lot of old glue and some fresh paint, this was the much less crap bumper. Ah and I 3Dprinted myself a new front badge.
This angle also shows how critical some front wheel spats/canards are to clear air from the front wheels.
Oil Cooler
Rad Duct
Brake Duct
Front bumper
- beavis
They sure are cool... but I'm not sure my budget can stretch that far
- beavis
Ahh so I am pleased to say I have a new episode out on my YouTube channel with some updates on the car
This video details how I made up the aluminium sheet radiator ducting.
Awww man seen this one already!
