Andrew's '93 NA6 - KL V6 swap
itrungs
Re: Andrew's '93 NA6 - KL V6 swap
Postby itrungs » Tue Feb 26, 2013 10:36 pm
Oh wow, thats an awesome N/A power figure for a miata. I'm aiming to get close to those numbers with the NA8 BP engine but i'm pretty sure I wont get close lol.
Why not go north of that figure and aim for 160 rwkw.
Beelzeboss
Postby Beelzeboss » Tue Feb 26, 2013 10:49 pm
Hahaha, thanks :) What are you doing to the BP to get that much power?
I don't *really* have any goals as far as power is concerned, it will make however much power it makes. At the moment I just want a running V6 MX-5, lol. If I feel it needs more power I'll mock up a supercharger setup on another engine to drop in at a later date.
While I'm a huge fan of N/A tuning, supercharging just makes a whole lot more sense to me when chasing more power (especially since I already have the charger)
Andrew
NA-6 2.5 KL V6
http://barberprecision.com.au/
itrungs
Postby itrungs » Tue Feb 26, 2013 11:22 pm
It'll be pretty much a high powered N/A build running on E85. No stroker kit though, since the cost of it doesn't outweigh the benefit and I'll be going for some mild cams since I still want it to be streetable.
I'm not necessarily aiming for a power figure, moreso power to weight like yourself. If more power cannot be obtained without keeping it streetable, I'll just remove some more weight from the car.
Postby NitroDann » Wed Feb 27, 2013 9:06 am
If you put in girly cams you will get girly power.
Postby Regie » Wed Feb 27, 2013 11:45 am
NitroDann wrote:If you put in girly cams you will get girly power.
Haha may have just found my new sig.
Postby manga_blue » Wed Feb 27, 2013 12:11 pm
You haven't been watching NASCAR, have you Dann?
Beelzeboss
Postby Beelzeboss » Wed Feb 27, 2013 5:47 pm
Hahahaha :D
I finished the sump today. NO LEAKS FIRST GO! That never happens so I'm pretty happy with it. I also added the threaded boss for the sump plug and the dip stick mount :)
Tomorrow I've got a few mates coming round to help put the engine in. If it wasn't for having a leaky injector I could probably start it tomorrow.
Speaking of which, does anyone know where in sydney to get injectors cleaned cheaply? Or does anyone have an ultrasonic cleaner I could borrow?
Andrew
NA-6 2.5 KL V6
Postby NitroDann » Wed Feb 27, 2013 7:20 pm
I said girly not attractive :P
Apu
Postby Apu » Wed Feb 27, 2013 7:29 pm
^how appropriate. And Danica too!
rxmx
Postby rxmx » Fri Mar 01, 2013 2:51 pm
Nice work, your welds are getting much more consistent.
For injectors go see Mick at wenty spares and performance in wentworthville, tell him I referred you he will look after you and tell him what its for he has a turbo mx himself.
Suli,
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
MrRevhead
Postby MrRevhead » Fri Mar 01, 2013 4:03 pm
^^ Small world!
Mick is a childhood mate of mine lol
rxmx
Postby rxmx » Fri Mar 01, 2013 6:27 pm
Ahh yah, Mick's a good guy, very fair with he's prices
Beelzeboss
Postby Beelzeboss » Sat Mar 02, 2013 12:20 am
Thanks rxmx, I'm going to first try to DIY them but when that fails I'll definitely look him up :)
The engine is back in the car, no pics because it's been raining since it was installed. I made the sump 5mm offset towards the passenger side, that's how far I thought the engine was but it turns out the engine is offset 10mm so there's very little clearance for the sump on the drivers side (2-3mm). I think I can get around 8-10mm by some *slight* filing of a couple of the welds and a tiny bit of the subframe. I'm certainly not making another sump :(
Anyway, tomorrow I'll be cleaning the injectors and modifying the exhaust for a bit more ground clearance. That will probably take all of Saturday and Sunday and then I'm back at uni. However I have Tuesday and Friday afternoons off, as well as all of Thursday so I hope to have the car done really soon.
Left to do: mounts for the new mirrors, a new intake pipe, slight modification to the exhaust for more ground clearance, install the rear NB brakes :D
Then it's pink slip, unregistered vehicle permit, emissions test, engineering, blue slip, rego.
Probably done by next Christmas :roll:
Andrew
NA-6 2.5 KL V6
Beelzeboss
Postby Beelzeboss » Sun Mar 10, 2013 4:27 pm
I drove the car for the first time today! However it seems to have a weird issue which I'm hoping someone can help me with. It sometimes backfires through the intake when it's cranking and doesn't like to rev very well.
http://www.youtube.com/watch?v=hLBRH1bFhzk
I suspect the cam timing is 1 tooth out but I can't be sure, does anyone know what else the problem could be?
Andrew
NA-6 2.5 KL V6
Postby manga_blue » Sun Mar 10, 2013 4:51 pm
For the backfiring during cranking it can be simple as not enough cranking power. Try jumper leads onto a bigger battery.
Otherwise there are the usual candidates for the rough running: ignition timing, ignition leads, plugs, fuelling, valve timing.
I've exactly had the same symptoms on a DOHC Fiat of mine but I hesitate to mention it cos it's so rare: sheared exhaust cam lobe.
