Ok so the install has progressed a little and some issues have been resolved and new ones have been found.
This is only for mocking up and once happy it will all be removed and done properly so don’t panic if you see hoses without clamps ect.
The existing clearance issues that concerned me was the dump pipe would touch the brake lines and getting the hot side intercooler pipe onto the compressor outlet was impossible due to PS lines and radiator hoses.
Well firstly I fitted the dump pipe and it’s not an issue. there is the same clearance on the brake lines with the dump as there is on the elbow.
I’m going to run a heat reflecting sleeve over the lines just to be safe, I’ll do the same with the A/C.
The PS lines and radiator hoses were a little trickier but nothing bad.
Firstly I removed the 2 piece NA lower radiator hose and hard line.
I fitted a flexi 1 piece lower radiator hose.
32mmID and 508mm long fits perfectly and runs closer to the Air con compressor than the frame rail.
NB lower hose may of worked but not given this much clearance.
For the PS hoses (these are the low pressure ones) i purchased new longer general purpose oil hose.
I routed the smaller one Around next to the frame rail and under the old bracket for the radiator hose hard join. The factory mazda hose was only about 50mm too short.
As for the bigger one which is easy to spot being red is looped away from the charger with the fitting on the pump rotated down slightly.
I pulled the sleeves off the factory lines and fitted to the new lines to prevent rubbing.
I will also put heat sleeve on both of these lines to help with radiant heat.
Below is before.
Below is after, excuse the filth everything will be cleaned after mock up.
The only thing rubbing here is the old bracket on the silicone join to compressor, I will trim this down or possibly cut it off all together.
A few more pics
Intercooler in for mock up, that’s bug splatter near driving light not cracks, intercooler fitment is perfect and you can see how much space is above for air to go to radiator, I’ll get better pics later.
It mounts to the bolts for baby teeth tow hooks.
Also I have the adjustable wastegate bracket and it has solved issues there with actuator rod alignment after clocking the turbo. It’s a stainless Mamba item from eBay.
This wastegate actuator is only being used for mock up and a turbosmart adjustable is going on.
This current one is the same dimensions as a Garrett/turbosmart GT actuator not a GTX one.
Some may notice above that the Mishimoto radiator is in, fitment was perfect no issues at all with the radiators fitment and it seems really good value.
However it does bring some other issues into play due to thickness. Wouldn’t be an issue on a non turbo or some other kits.
Main problems are fitting a top radiator hose and the fan for AC hits the throttle body silicone join.
Pictures tell a thousand words.
I will need to run a slim SPAL fan on this side, I cut and modified the factory shroud, spent hours on it actually and it still hits badly.
The engine fan is fine on the other side even with my fatter whiteline away bar.
The only solution here is to cut the top radiator pipe and weld at an angle, even with the standard radiator this intercooler kit will not work without a coolant re-route as seen below. I’m very seriously considering the FM re-route.
The empty port on the silicone hose is for the BOV, there is one at the back that goes onto the IACV so the hose can’t be rotated.
This port as shown below also highlights the fact a reroute is needed.
I do have the 323 timing covers so I will delete the thermostat neck completely and fit them which will cover the timing gears as another added bonus with the re-route.
Above the radiator hose is resting on outlet.
The two pictures above are with the factory radiator.
So I need.
- a slim SPAL fan for AC, I have found one rated around 1100cfm like the factory unit that should fit.
- re-route, which was planned already but is needed now not just wanted.
- cut and weld radiator top hose to face more towards the drivers frame rail for the re-route hose.
So a few little headaches but all in all it’s getting there.
I have been looking at ducting ideas for heat exchangers and how I’m going to tackle the airbox. It’s starting to get past the headache stage and the fun has begun.
