Speed's boosted NA6
lightyear
Infinity & Beyond
Re: Speed's boosted NA6
Postby lightyear » Sun Sep 10, 2017 9:27 pm
I like all your mods, you have done well. I sometimes want to have a completely stock NA, but then they look good with tasteful mods too. That's why I have 2 maybe.
speed
Re: RE: Re: Speed's boosted NA6
Postby speed » Sun Sep 10, 2017 9:58 pm
lightyear wrote:I like all your mods, you have done well. I sometimes want to have a completely stock NA, but then they look good with tasteful mods too. That's why I have 2 maybe.
Thanks Dave. I still like a good stock NA too :)
beavis
Postby beavis » Mon Sep 11, 2017 12:34 am
Nice work good sir, looking great :)
:NA8:
shirtz
Postby shirtz » Wed Sep 13, 2017 9:40 am
agreed, much inspiration!
StanTheMan
Postby StanTheMan » Wed Sep 13, 2017 9:56 am
very nice indeed :mrgreen: 8) 8) 8) 8)
Postby bruce » Wed Sep 13, 2017 12:36 pm
Regards fitting the beanie and wastegate arm. I guess you have to cut a hole in the beanie and remove/refit the circlip?
speed
Postby speed » Wed Sep 13, 2017 6:36 pm
beavis wrote:Nice work good sir, looking great :)
:NA8:
shirtz wrote:agreed, much inspiration!
StanTheMan wrote:very nice indeed :mrgreen: 8) 8) 8) 8)
Thank you gentlemen.
Beavis, it's a NA6 with some NA8 bits :)
speed
Postby speed » Wed Sep 13, 2017 6:37 pm
bruce wrote:Regards fitting the beanie and wastegate arm. I guess you have to cut a hole in the beanie and remove/refit the circlip?
Yes Bruce, exactly that.
The hole is tight and the beanie sits flat in that section to not catch on the wastegate arm.
speed
Postby speed » Sun Sep 17, 2017 3:52 pm
So my SSB battery has been dying for a while now, to the point that it wont hold charge between weekends.
I checked out my local distributor and had a choice of paying more for an AGM Federal or getting the same vented SSB battery again.
I chose the cheaper SSB as it had a higher cranking rating, was lighter and lasted for 60 mins as opposed to 45. My last one also lasted 3 years which I figured was good enough for $139.
Since the battery was coming out I thought i may as well check the condition in that area, knowing the PO had the wrong type off battery when i first bought the car.
This is what it looked like!
So I hit it all with a wire brush, some drill attachments and sanded the rest.
Then vacuumed, cleaned and bathed it in rust converter overnight.
The next morning I wiped it down, masked primed and painted in matt black.
Drove the car today and absolutely swear that she runs and sounds smoother.
Perhaps the old battery was affecting more than just starting tge car.
Anyways very happy with the outcome :)
Daffy
Postby Daffy » Sun Sep 17, 2017 5:10 pm
Looks almost new again :BROADY:
viewtopic.php?t=73496
beavis
Postby beavis » Sun Sep 17, 2017 6:16 pm
Heyy, super neat work! I've seen so many MX-5's have a battery area that looks like your BEFORE pic. :DIY: :DIY: :DIY:
StanTheMan
Postby StanTheMan » Sun Sep 17, 2017 6:28 pm
Love your work Speed. always sooooper clean 8) 8) 8)
Postby KevGoat » Sun Sep 17, 2017 6:52 pm
Nicely done
two40
Postby two40 » Sun Sep 17, 2017 9:00 pm
Good save there. I absolutely detest rust. Gives me shivers.
George
WTB
- Early NA Radio
- Crash pad for '89 NA
headlightsgoup.com
speed
Postby speed » Sat Sep 23, 2017 4:52 pm
New knob. This one is taller.
I also greased up both balls on the short shifter. Seems to shift easier whilst sitting in my garage but the true test will be when I go for a spin tomorrow.
Also re-fitted my sparco as I was concerned that I'd smack my head on the roll bar.
Users browsing this forum: No registered users and 27 guests
