BEAVIS' White Track Car
beavis
Re: BEAVIS' White Track Car
Postby beavis » Wed Nov 30, 2016 11:59 pm
It's so WAY over the top isn't it. Truly impressive.
Sadly I didn't attend WTAC this year, but the live stream is really good.
The diffuser/underbody on the S15 has been like that for about 2 years now I think, as I did get to see it in person a few years ago.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Dec 02, 2016 11:19 pm
andrew brilliant has claimed that under suzuki's s15 is the highest downforce car in the history of humanity. i referenced an old school under body style car that had over 10k pounds of downforce and he said yes i have taken that car into account and under's has more.
Earlysport
Postby Earlysport » Sat Dec 03, 2016 9:22 am
Do you have access to a set of scales Beavis? Keen to see how light your car is after all this surgery.
beavis
Postby beavis » Sat Dec 03, 2016 2:50 pm
16bit wrote:andrew brilliant has claimed that under suzuki's s15 is the highest downforce car in the history of humanity. i referenced an old school under body style car that had over 10k pounds of downforce and he said yes i have taken that car into account and under's has more.
:shock: I did not know that, I am impressed. The scary thing about that is, it really is so much of an unknown, people just don't really know what else they need to do to a car to support all this mystical aero stuff. Sure engineers can use their brains and fancy mathematics, but, real world testing always brings out surprises. And these cars are next level.
Earlysport wrote:Do you have access to a set of scales Beavis? Keen to see how light your car is after all this surgery.
It will be my pleasure to let you know how corner weights when it is weighed. I would be happy with 950kg as a start.
Apu
Postby Apu » Sat Dec 03, 2016 3:18 pm
I'd be surprised if you don't hit 950kg. My Integra is 950kg and not as stripped out as your car!
beavis
Postby beavis » Sat Dec 03, 2016 7:17 pm
Added weight of the roll cage.... and front, underbody and rear aero.... it hurts.
Apu
Postby Apu » Sat Dec 03, 2016 7:20 pm
Yes, I have a 6 point cage, splitter, rear diffuser, wing etc...and it still has the heavy glass on the rear hatch (albeit carbon)
beavis
Postby beavis » Sat Dec 03, 2016 7:25 pm
What times does it do?
I drove a DC5 type R and it was pretty damn fast, though I think at the time it was a $20k car with another $20k of honda fanboy mods.
beavis
Postby beavis » Sun Dec 04, 2016 1:00 am
Sometimes I hate doing this stuff
So some idiot cut a bunch of holes in my car and now I have to fill them back up.
So... bust out some CAD. I think the pictures say it all here.
The side sections need a slight kink about 3/4ths of the way along.
The sides will be mounted permanently, the middle section however will be bolted in for removal to make for easy access to... stuff?
The middle section has a kick up at the rear to meet the rear of the boot.
The carboard templates will be replaced with fibreglass panels weighing about 1/8th of the steel it replaces.
Oh by the way, take it from me, safety should always come first... my index finger had a close call with the grinder cutoff wheel because of the awkward cutting that was necessary.... so please always take care!
Apu
Postby Apu » Sun Dec 04, 2016 10:18 am
beavis wrote:What times does it do?
I've done 1:11 at Wakefield but Benny Tran has done high 1:09 with a passenger, running AD08Rs. Stock engine with intake, header, exhaust and Hondata ECU.
madjak
Postby madjak » Sun Dec 04, 2016 11:25 am
Yeah watch those grinders. I trimmed my middle finger shorter by a bit a month ago. I was wearing gloves but the wheel grabbed them and pulled my finger in to the blade.
I'm following your thread closely. I'm not sure I want to totally hack up my car yet but this is along the lines of what I was thinking. It will depend on how fast my competition is next year. Might have to do a tubular front end with a gutted rear :)
npcan2
Postby npcan2 » Mon Dec 05, 2016 10:06 am
Hi, this is me.
It had intake + JDM intake manifold, headers, exhaust and a tune. 143kw atw at 1160kg. It felt fast because the gearing allowed it to stay in it's power band (vtec yo).
plohl
Postby plohl » Mon Dec 05, 2016 10:32 am
I have a standard dc5r.
It is fast... compared to the mx5. I think it was a bit faster than my housemates 86 as well - mostly due to the dip in power the 86 have around 3-4k. Every time i drive it, i really just want to put the engine in the mx5...
My car is 980kg with a cage and standard hardtop and i think 3/4 tank of fuel, so i would assume you could comfortable get 950kg. Although i'm not sure how much weight the aero/ducting etc will add... and turbo's aren't exactly light either...
plohl
madjak
Postby madjak » Mon Dec 05, 2016 12:45 pm
plohl wrote:My car is 980kg with a cage and standard hardtop and i think 3/4 tank of fuel, so i would assume you could comfortable get 950kg. Although i'm not sure how much weight the aero/ducting etc will add... and turbo's aren't exactly light either...
Mine is 920kg without me. Thats with a full cage and interior. As with plohl, I don't have a turbo and all the guff that goes with it either. Also no chassis bracing, small radiator, alternator, battery etc etc. I think I'll be able to get it under 900kgs with a bit of work.
beavis
Postby beavis » Mon Dec 05, 2016 6:53 pm
madjak wrote:I'm following your thread closely. I'm not sure I want to totally hack up my car yet but this is along the lines of what I was thinking. It will depend on how fast my competition is next year. Might have to do a tubular front end with a gutted rear :)
Likewise. One of us will do the tube front end - bets on who does it first?! :D
madjak wrote:Mine is 920kg without me.
There's clearly a weight penalty by running the NB over the NA. For reference, this car was about 970kg without driver in the previous sans-turbo setup.
plohl wrote:i'm not sure how much weight the aero/ducting etc will add... and turbo's aren't exactly light either...
My old setup (wing, splitter, flat floor) would have added a good 30 or more kilos I reckon, it all eventually added up. But it also made it a very capable car.
Users browsing this forum: No registered users and 27 guests
