But as the ITB's don't generate the vacuum the booster needs and you like the feel, get rid of the booster.
A few reasons, weight, better feel, more room, easier to fit a dual master cylinder set up with the obvious advantages for adjusting brake bias and one less thing to go wrong.
Now to get the times down to a level that is equal to the car
I am hesitant to use GPS data alone as unless you have DGPS the accuracy is only around +/-3m for the newest Sirf IV chips. For points close together in time the relative accuracy is good, but you don't know what the drift in accuracy is from lap to lap and when you are looking for a couple of metres it is very difficult when the accuracy is only good to 5m. Better GPS accuaracy is scary expensive with real sub metre accuracy on the fly $5k plus, and then that's not guaranteed for 100% of the time.
