Stuart & Lisa's MINX
Re: Stuart & Lisa's MINX
Postby Lokiel » Sun Feb 21, 2016 1:11 pm
Not sure if you've done it already or not, but as a Queenslander while "down Mexico way", you might want to visit the southern-most point on the mainland, the tip of Wilsons Promontory in Victoria (one more thing to tick off the bucket list).
MINX
Postby MINX » Wed Oct 12, 2016 3:32 pm
Update October 2016
SE still daily dríven, in fact more now than ever in its life.
There about 178,000kms
Current wheel count at 16
4 RHs, in the garden.
8 Gen2 Nickel 6ULs, 4 with Nittos, 1 with cracked spokes, 3 spare.
4 Barillium 2016 6ULs 15x8 with daily Neogens
Sent from my iPad using Tapatalk
Postby bruce » Wed Oct 12, 2016 4:09 pm
Maate, I think you need a shave (and your nails clipped).
Woof!
ManiacLachy
Engaged
Postby ManiacLachy » Wed Oct 12, 2016 4:10 pm
Looking good, Stu. In the pictures they appear to have a bit of a blueish hue, is that there in person?
What happened to the Nat Meet banner? I thought you always kept that. I'm glad to see there's another DD SE out there. :beer:
Postby Lokiel » Wed Oct 12, 2016 5:03 pm
MINX wrote:Update October 2016
You trying to grow some more?
They're not like potatoes.
I thought you might use them on the boat as anchors :twisted:
Can you post some shots of the Beryllium rims on the car in sunlight?
From pictures I've seen, they look like a close match to the Titanium colour but I haven't seen a good photo in sunlight of them on a Ti.
Will be interested to see if they "nick-up" like the Nickel rims do (ie. lose small chunks of nickel plating, leaving black pock marks)
MINX
Postby MINX » Thu Oct 13, 2016 2:00 pm
They are a touch blue
But not bad in the sun
captaincabinets
Postby captaincabinets » Sun Oct 16, 2016 11:38 am
I was reading a thread recently, Emilio from 949 says he was going for that, hint of blue in the shade.
MINX
Postby MINX » Fri Oct 28, 2016 11:29 am
#cleanas
Postby Magpie » Fri Oct 28, 2016 11:49 am
The grass looks like it needs to be washed as well :)
smy0003
Postby smy0003 » Fri Oct 28, 2016 11:49 am
Hahahaha looks like it does what it says on the tin.
Where'd you get it from?
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Postby Magpie » Fri Oct 28, 2016 12:04 pm
MINX
Postby MINX » Fri Oct 28, 2016 12:24 pm
Sprinklers on now Magpie!
Postby Magpie » Fri Oct 28, 2016 4:59 pm
So the 'stuff' makes the lawn shine as well :)
speed
Postby speed » Fri Oct 28, 2016 5:51 pm
Man, that's a lot of grass!
MINX
Postby MINX » Wed Nov 16, 2016 12:29 pm
After about 90,000Ks Daily duties and track time, car was handling badly, crashy and rattly.
Right rear BC BR damper stuffed.
Replaced 'inserts' on both rear coilovers
All fixed, ride comfort and handling back to normal in two hours!
$390 for two replacement dampers delivered.
Glad it was the rears.
Reasonably easy job. https://vimeo.com/191732584
