Cus' NA6
Cus
Re: Cus' NA6
Postby Cus » Sat Oct 22, 2016 9:46 pm
StanTheMan wrote:most likely not around a long series of corners unless the nutter driving is is totally insane.
Definitely not, unless work want to start putting ad08r's and stiffer springs on the work cars (I'll take the interior out free of charge...) :lol:
This morning I got new spark plugs, because ... why not. I've done 80,000km on these ones, plus whatever k's the P.O. put on them before selling the car to me, used my shiney new torque wrench to torque them up to spec and everything, was all kinds of exciting.
Where the story gets interesting is the top of the spark plug / bottom of the COPs were covered in what I'm going to call soot. It was black, not shiny, caked on and there was lots of it. Also three of the four springs in the COPs fell out and needed manual intervention to get them to stay in there. (also, fishing COPs springs out of the spark plug holes isn't fun)
At a guess the loose springs is related to the soot, I'm fairly sure it's not supposed to happen. Any suggestions as to a cause and/or solution?
Pictured: the soot.
I also ghetto'd up some heat shielding for the intake parts that are near the exhaust: lengths of aluminum foil, scrunched up, flattened out, folded lengthwise in thirds, re-scrunched, re-flattened, wrapped around the intake ducting, and tied on with wire. Does it work? It seems to, looks like I'm saving about 10 degrees with the lights down, and with the lights up the intake temp goes to almost-ambient much quicker. Hopefully this will stop it's occasional stalls after it's been dríven for a while and stopped for a few minutes (ie; getting fuel on a road trip), intake temp would end up reading basically whatever the under-bonnet temp was until you started moving fast enough to cool the temp sensor. (it's in a sh*t of a spot, I'll move it when I have an intercooler to plug it into)
Side note; played with the megasquirt all afternoon, in an attempt to setup some lean-cruise. dialled 15.5 into the AFR tables in the spots I wanted, drove around doing auto-tune for a good long while, then took a log while I toddled home. Get home, review the log and see it's still hitting 14.7 in the cruise cells. VEAL set to "Hard" makes very, very, very small changes it seems. Not registering MLV is also a pita, 5000 log entries is about 2 minutes of driving.... oh well, it is done now, I'll found out next week if it makes any difference, commuting to work netted me 7.9L/100km
Cus
Re: Cus' NA6
Postby Cus » Mon Oct 31, 2016 9:55 pm
I have a feeling the previous issue was the COPs not being pushed down far enough onto the plugs, I've trimmed the rubber grommit on the bottom of the COPs down and now they noticeably click into place.... but I'm up for new ones, the rubber boots are burnt out and the springs have fallen out of most and the car sounds a little bit unhappy.... oops.
Does anyone know if you can get the rubber boots and springs separate, or should I just drop the $25 each on new(er) COPs?
Side quest for the evening: Power windows started playing up. Then the central locking. Then the interior lights.
I blame this guy: (the missing wire on the coil, not the dodgy soldering on the ends)
bartmanftw
Re: Cus' NA6
Postby bartmanftw » Mon Oct 31, 2016 10:43 pm
I can give you some spare boots/springs for the toyota cops if you like?
Cus
Re: Cus' NA6
Postby Cus » Mon Nov 14, 2016 9:14 pm
Cus' JDM garage has doubled in size!
Here follows a review of the works cars I've been spending time in....
I finally have my own work car, a 2008 (i think) corolla. I like it, it's manual, rides OK, handles OK, has enough poke, 6 gears and generally, behaves as you would expect an N/A 4-cyl japanese would, over 4k RPM it does things, under that it moseys along nicely. The clutch has no feedback at all, and cruise control would be excellent, but aside from that', it's not bad.
Work is slowly rolling out Hyundai i30's, which I'm really hoping I can avoid for as long as possible, I had a couple out of the pool (people on my contract get cars because they're almost never in the office, most of the office-people have to use cars out of a small pool of 'spare' cars) and everyone seems to think they're good. I personally think they're shithouse. They ride like they'd handle OK, and they handle like they should ride OK, But neither is true, they're bumpy to ride in, and don't handle. (ie; taking 80km/h posted corners at 100km/h is sketchy as f*ck, the rear end loads up and offloads and .. it's sketchy, don't do it) The seats have a stupid headrest that only works if you've got kink-neck, there's so much shiny sh*t on the dash driving on sunny days is a form of torture, and it either goes excellently, or not at all. eg; going up a steep hill applying more throttle has no effect until it kicks down a gear and takes off like there's free candy. Same with overtaking, mashing the foot into the floorboards either results in a burst of power, or not, you'll find out after you mash the foot into it.
In short; i30 = Bad; Corolla = Good.
MX5 = Excellent still, which is proven every time I get back in it after driving the work cars.
(also, conveniently, I now have 4 spare COPs to see if swapping out the ones on little red will make it happier... :twisted: )
speed
Re: Cus' NA6
Postby speed » Mon Nov 14, 2016 10:04 pm
Your descriptions make me smile. Now you just need to work your magic and convince your boss that you need a ND :)
Cus
Re: Cus' NA6
Postby Cus » Tue Nov 15, 2016 6:39 pm
speed, if you can find me an article that says the TCO of an ND is less than an i30, I'll definitely give it a go! Hell, as long as it doesn't look too fake, I'll even take a creative-writing submission! :lol:
Talking with the person who was the one that decided we all need i30's, they kept saying "but it's a diesel" to nearly every comment I made about preferring the corolla to the i30, it reminded me think of this.
speed
Re: RE: Re: Cus' NA6
Postby speed » Tue Nov 15, 2016 10:58 pm
Your response could have been; "but it's a Hyundai"!
The American
Re: Cus' NA6
Postby The American » Sun Nov 20, 2016 6:45 am
The diesel auto is a bit woeful, but the manual diesel can be good fun. (An i30 diesel won the challenge class of the Targa West rally a few years ago)
Cus
Re: Cus' NA6
Postby Cus » Tue Nov 29, 2016 10:20 pm
I drove little red on sunday, and ended up with sunburn.
The weekend before it started overheating on a club run, and I swapped out the COPs with known-good ones (thanks droo!) Swapping out the COPs was good, autotune actually started pulling fuel (my first indicaiton that something was up was when I was trying to do a lean-cruise tune and it was *adding* fuel) .. but now I have a strange hesitation sometimes while going from no throttle/not moving to "moderately into it" - it hesitates for a bit, then wakes up and goes. (this is in a 14.7 part of the map, my lean cruise is only in the 100km/h 5th gear cruise RPMs) but also sometimes when I start it it seems to only run on half of the spark plugs, then suddenly comes good, I need to double-check the cops wiring.
The overheating is caused by a) the LED light bar in the mouth of the car, b) the lack of undertray, c) the massive gaps between the fans and radiators - I will fix some or all of these over the course of the next few weeks and see how it goes in a few weeks, most of my spare time has been booked out so my sister can get married next weekend.
Last night I started toying with air box designs, today I forgot I wasn't driving it and took a yellow "40" corner at 70, and tonight I ate a whole lot of chocolate and then went for a long, brisk walk.
So, nothing to report really, except that I need to do things, and can't be stuffed. My job consists of warranty and damage repairs on desktops and laptops. Schools have laptops now. Kids break laptops. School is nearly over for the year, and lots of kids want their broken laptops fixed before the school holidays.... I haven't done a regulation 7.6hour day in about three weeks, and the tax man keeps taking all of my overtime. Stupid tax man. July will be awesome though!
Cus
Re: Cus' NA6
Postby Cus » Sat Dec 10, 2016 1:36 am
Friday is Roadster day!
I back little red out, put the work car in the back yard, and it's 2 days of roadster love!!
Well..... It was going to be, until there was a metallic snapping sound.
The window went down fine. Then ... that's where it stayed. Currently the broken wire is tied to top of the door frame, because it stops the window from slipping down.....
/facepalm
smy0003
Re: Cus' NA6
Postby smy0003 » Sat Dec 10, 2016 3:13 pm
Ahhhh well, perfect day for top down, window down driving.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Cus
Re: Cus' NA6
Postby Cus » Sun Dec 11, 2016 9:32 pm
It was the perfect weekend for it really.
I dodgied up the driver's side window by wrapping that broken cable around the top of the door frame (there's a factory hole there and everything!) so the window would stay up, then I went to the grampians for the weekend, with the roof, because tinted windows are actually the bomb.
While I was "fixing" the window I seem to have knocked the door lock/open rods out of their correct location, the central locking isn't working, and the door intermittently can't be opened from the inside. Some lucky people got to see a grown man crawling out of the passenger door of an MX5 a couple of times in and around the grampians.... :lol: Right now at this very point in time, the passenger side cannot be unlocked from the outside of the car (broken lock barrel that I've been meaning to get fixed since about 2 weeks after getting the car), and the driver's side cannot be opened from inside the car. I'll go ahead and call it a security feature.... :roll:
I had a ball driving around to the various tourist traps, and after my third attempt in two days, actually managed to get a clean / no traffic run down the one-way road.
I was pretty happy, but not nearly as happy as one of the "bad" runs where i caught up to a camper van with 'I DON'T DO DRUGS, I AM DRUGS" written across the back in giant letters. It turns out I don't mind being stuck behind traffic that makes me giggle.
Cus
Re: Cus' NA6
Postby Cus » Mon Dec 12, 2016 11:20 pm
I've started the discovery process for repairing my window winder.
There's a high-res photo gallery here, which will be updated as I go on.
http://imgur.com/a/9Nftj
Once the task is complete, I'll make an actual post on how to do it.
The passenger side will probably need some preventative maintenance on it based on the look of the drier's side, so I'll have fresh material for the second round!
Cus
Re: Cus' NA6
Postby Cus » Sun Dec 18, 2016 2:40 pm
*Theme song for Fresh Prince of Bel-Air plays in the background*
Now this is a story all about how
My window stuck right down
And I'd like to take a minute
Just sit right there
I'll tell you how I repaired this thing right here:
So, as you can see, one cable is broken. The internet wisdom is that it's just a bike cable, and you just put it in, and hey-presto! things are fixed. But this is not that kind of story, because that would be a boring post... :P
Anyway, on with the shenanigans!
I took the motor off the slider, so the ends of cables were free, this made it easier to clean the old grease out.
The white thing under the cover with the 2 screws I've decided is named "Barrel, Minor Deity of the Window Mechanism", you will offer many prayers and curses in His name.
The individual cables are wound on to opposite ends of the barrel so one grows and one shrinks, causing the window mechanism to move.
The window-up cable is the broken one here (bottom cable externally), and it's at the top of the barrel as you look at it, the window-down cable (top cable externally) starts at the bottom of the barrel.....for the driver's side, I'll let y'all know when I do the passenger's side.
Rags supplied by the supermarket's brand 20-pack, in the cooler months used ones start the fire in the shed like nobody's business.
This cable is both bent, and frayed, and it's the "good" one... I thought I could get away with it, but this one needs to be done next.
I (now) know what causes this: a lack of tension in the cables, which means the cable wraps up (or pulls) on the cable on the barrel instead of moving the window for a small amount each movement, stressing the cable, fraying it, and eventually breaking it. If you have a cable that looks like this, it needs to be replaced too, otherwise it will cause the new cable to fail in the same way due to a lack of tension.
Remember to wind the black cable tensioners on the motor all the way in once you pull the wires out, you'll need the adjustment later. I didn't, it wasn't fun...but I did learn about the bunching/tension thing, so that was nice.... If it makes a crunching sound when you first run it, that means you get to do it again! All Hail Barrel Deity!
Definitely have a friend or some kind of genetic mutation that gives you and extra set of hands. Maybe a vice. A swarm of nano-bots if you've got 'em. Anything more than two hands is a must.
We start with this bad boy right here, it's 1.7 Meters of mouintain bike brake cable.
As you can see, It's not even remotely the same size, the original item fits snugly in the hole. It was time for surgery!
I used a hacksaw to cut the meat off the sides, and a file to shrink it radially. I also then, stupidly, cut the cable to the "right" length. Do not do that. It is not a good idea. It is the kind of idea that leads to regret. Just lop the unwanted end off the cable, and cut it to length once it's tensioned. Trrrrruussst me.
Eventually it fit snugly into The Great Barrel.
All wound up on His Holy Benevolence, Barrel. This is waaayyy too loose. Attach the cables to the slider so you can get a good amount of tension on it before you try to move it. Do not run the motor without tension on the cables or you will get to roll the cable back onto His Malevolent Omniscience, Barrel.
Notice how the tensioners still aren't screwed in here? Yeah, Future Cus is going to have a bad time.
Because the cable I had didn't have the other end in the required location, I used a bolt and a washer with a flanged nut to clamp the cable in place. This is where cutting the cable came back to get me. I should have done it like this:
But that may interfere with it going all the way down... I may need come up with another solution. Future Cus will work this out for us.
I got it reassembled (a few times) and in the car, and tensioned, and all sorts of good things, and took exactly no photos, because i just didn't have enough arms and legs left to work a camera as well. Anyway, installation is just the reverse of removal ;)
It's bunching up a little bit here. That means there isn't enough tension in the system and this cable is eventually going to fail the same way, so I needed to replace both of them at the same time.
Notice the tensioners? Yup... I completely forgot about them until approximately this time... But I was fighting an uphill battle because of the other cable being dodgy and impossible to pull enough tension on.
...and I did exactly no research on this matter. ...
I just figured it would work and the cable was only "like, I dunno, 3.95 man?" at the bike shop, so it was a pretty small gamble.
I've also devised a method of holding the window up with zip ties as well, so I've got options. I should have got photos of this. It's basically a bolt with two nuts in place of the middle-top end-stop and a zip tie around bolt and the end-stop on the window pulling the window up. It holds the window up, but I wouldn't drive too far.
Proposed method: wind the tensioners all the way in, use two fresh cables, don't cut them to length, tension it up as tight as possible via the mounting method I devise, then used the tensioners to wind in some extra tension, offer sacrifices to The Almighty Barrel, test it, only if it's successful cut the excess off.
Here we have the net result of the cable being bolted in it's current location, the top of the runner needs that space to get all the way up. Conveniently, having the end stops set all the way down stops it almost the same time, so it "shouldn't" destroy the roller, plus I have the current limit thingy going on with the arduino so once it's at the predefined maximum load it will turn the motor off. This usually triggered after crunchy sounds too. I shouldn't kill the roller from binding up on the bolt before next weekend at any rate.
So now I'm up to sourcing 4 more cables, and working on a better cable attachment system. I might even put some effort into finding ones of the correct end size to make life a little bit better. Or even part numbers... anything is possible!
(I know, I lied, it's not fixed)
smy0003
Re: Cus' NA6
Postby smy0003 » Mon Dec 19, 2016 8:08 am
Oh man that's my idea of hell. At least Victoria hasn't decided to flood your car with rain.
Sent from my LG-H815
