Car is ready to go back on the ground. Fixed the dodgy cold side elbow below the RB bar, where the pipe had to be moved back to make way for the RB brace. Eventually it will have to be welded up, but later. I have to dig out my alternator, because Chris the Autronic guru is coming up to tweak the software so it can control the standard alternator. To give better access, the radiator will be left out. The new fittings and hose for the oil cooler are installed, ready for connection.
Bushes have been greased, still waiting on the caps though. Wiring for the oil temp and pressure installed.
Dann, your airbox is a b****d to access the filter. Too hard for an old fart! So, I took the angle grinder to it
It now sports a big 'ole on the top. Rivnuts will be inserted in the perimeter of the said 'ole, and a hugely expensive slab of solid electricity will be bolted down to reseal it, but also to provide easy access to maintain the filter. With my dusty access road, that is a must. Photos of the Red GreenMachine Ezy-access Mod will be available in due course, subject to payment of the usual fee of course.
Now, to get that jack out, and get the rubber back on the ground ...
