ohh, except this bit.... really?
CarMakeRevive- SR20 6speed tube drift mx5
Re: RE: Re: CarMakeRevive- SR20 6speed tube drift mx5
Surely that's in jest. The drift scene is all about pushing limits. This is a pretty standard practise. It's a worry on the street but these with 50psi (cold) won't fall off, simply allows a super ridged sidewall and ability to run baller rims without heaps of power. It also means you can drop the car lower and not hit stuff.
Sent from my SM-G920I using Tapatalk
- bruce
- Vehicle: NA8 - Turbo
Those rims make me think of VIPpers.
- Jeo
Very nicely done mate. Please do keep us posted with the updates.
Insane build!
Where do you build your rims? Lookin at rebuilding mine and redoing the anodising on the lips, wondering if you could share any contacts or tips.
Tony
Tony
luzinit wrote:Insane build!
Wheel lips/barrels
I use WhiteHorseIndustries, they own all of Simmons Wheels old dies and tooling, talk to Craig, you can download their Proforma in PDF, fill it in and email for a quote.
I've used brisbane metal spinners, don't want to go into details but very highly don't recommend them.
I use A Grade Anadising at Ormeau, $40 per outer
Happy to share info
- bruce
I just rang Whitehorse Industries as they're local. They can make you the biggest barrels you want.
Revive, I'm guessing you're in Sydney?
bruce wrote:I just rang Whitehorse Industries as they're local. They can make you the biggest barrels you want.
Nah I'm in Brisbane, if you talk to Craig tell him that "Brett from Brisbane" put you on to him
More roll cage gussets, this roof is never coming off, it's now welded on, placed studs in the factory mount holes and welded them to the cage and b pillar supports
B pillars welded and smoothed
Windscreen frame gussets
Rear window gusset
Also finished the mounts for the window nets, so plenty done of late
Rear window gusset
- A.Chen89
- Vehicle: NB8B - Turbo
This is amazing, sick fab work!!
- beavis
From what car is that arm/hub setup you're using in the rear?
- plohl
It's all Silva stiff isn't it? Maybe s14/s15
plohl
plohl
beavis wrote:From what car is that arm/hub setup you're using in the rear?
The rear end uses Nissan s15 geometry, z32 300zx alloy knuckles and twin z32 callipers, ones for the handbrake, the front end is based of Nissan s13 silvia control arms and caster arms with AE86 struts, FD Rx7 callipers on Wilwood two piece rotors
Users browsing this forum: No registered users and 72 guests
