Dylan's 89' na6 build
Re: Dylan's 89' na6 build
Cheers man! the door cards are one of my favorite parts of the car!
"It's not about power. If you can't go fast with 90 horsepower, 900 ain't gonna help ya. I genuinely feel that."
Best of luck painting.
If you've got some sheet metal or a spare panel, use it for setting up the gun and test paint.
prep is everything. Sand, clean, tape, clean.
Practice to get a good quality even application. Dry patches or runs must be let dry before rubbing back and re spray.
If doing this outside, give it a good 5 coats of clear, should you need to buff anything out.
Don't let the paint dry between coats; colour, pearl or clear.
If the paint has dried. Rub it back before applying more coats.
Planning and prep is everything
Time to update this haha. So since the last post i made i have had to change the waterpump, thus replace timing belt at the same time. I also picked up some spacers so the wheels would sits better, got a new drivers seat, and finally got around to getting coilovers. also got a few other bits and bobs, such as a new radio. oh and am also finally off my L's haha
Next on the list is a new clutch, rear lip, rear spoiler and finally a respray
