Brett's pre mid life crises
narita
Re: Brett's pre mid life crises
Postby narita » Fri May 10, 2013 3:15 pm
MadMikey wrote:Wait, what exactly is the jet stream carpet?
I bought my garage vary & jet stream parts through Jesse Streeter and saved a couple hundred compare to Rev9; if you ever need parts sourced from Japan I recommend going through him if you're cheap like me.
Majority of parts on the wagon r were sourced through streeter. His a top guy.
The reason I went with rev9 is because I was under the illusion that he had stock
WINTON PB - 1:57.4000
narita
Postby narita » Mon May 13, 2013 8:36 pm
So I received a email from max @ rev9.
Sure to say I am very impressed with the way he handled the situation!
Money for the incorrect part will be refunded, turns out jetstream is deciding if they will continue production of their carpet.
Not much happening at the moment, adjusted the throttle cable and mounted it to the top hole.
Tyres are booked in for next week.
Pham is a top guy and should be sending me a sparco and visor camera mount soon.
Need some brake pads.
Got a helmet! Off to track next month.
