I decided to go with the BP6D oil pump (used on the VVT models and the SE) as it can flow more and is a bit beefier.
One other change I've made is swapping to a JDM tacho; it makes the redline area much easier to see with your peripheral vision on track days:
It is an easy swap to do however you will find the 0-2 area not as well lit as the rest of the gauge. The Australian cluster doesn't have anything in this area so there's no provisions for a bulb or light to get through. I don't find it to be a problem.
