98 evo gold
- 16bit
98 evo gold
stock for now.
- 16bit
98 evo gold
thanks - yeah i only bought them for asthetic and weight reasons.
- CapitalF
- Vehicle: NA6 - Turbo
98 evo gold
I really like it from the front, but the arse and side don't do it for me. Nice wheels. What? No CF hardtop to match??
Im -positive- the grunt factor would get me over the looks. :-D
Peter
Peter
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
- 16bit
98 evo gold
just got some nicely heat cycled semis for this years track days. Advan A048 in 225 50 15. they are seriously wide. I will be bringing these out at the second time I go as I would like to see the difference between these and my do1's with my current setup.
- d-mag
- Road Track Rally
- Vehicle: ND - Turbo
98 evo gold
Don't waste your time on streets while on the track if you've got some semis just sitting there. One of the best mods you can do to lower times IMO. Jump straight in man.
MX5 Wanted. SE or NC (forced induction preferred
- 16bit
98 evo gold
do1's are semis. they are the older style dunlop semi slick that has been replaced by the do3
- d-mag
- Road Track Rally
98 evo gold
Haha, my bad.
BTW, I had AO48s on a previous ride and they're an awesome tyre.
- 16bit
98 evo gold
werd - if they are good enough for the hks cr230 something something time attack evo they are good enough for me!!! i am hoping for about .5 of sec per lap improvement from these over the smaller older tyres. big i know but will be interesting.
- 16bit
98 evo gold
finally got my sparco in after trying 3 ways the last worked - as is to be expected. After trying to come up with a way of making a braket to mount to the stock rails and then side mount to the seat I gave up when i realised i would have to cut the seat belt bit a little. So one night trying to get to sleep another idea hit me. I thought I would bolt a bit of 40mm square aluminium bar to the rails creating a box then mount the seat to the aluminium bar. after a little trial and error it worked. And me not being the tallest man alive it also solved the problem of the seat being too low! i will post pics soon.
- 16bit
98 evo gold
a few updates. I swapped the aluminium bar to gal steel of the same measurements for the seat. I have also braced the front end so the slitter is supported by more then just the front bar its self.
I also just organised to purchase a wing for the track next week.
http://www.buddyclubuk.com/wing.htm
My problem is now do I drill my carbon boot lid or do I just put it on my stock one?
- Jeo
98 evo gold
Drilling carbon sure doesn't seem undo-able, but it would look much better
Sidenote, are you using bonnet pins?
And any chance of engine bay pics?
- 16bit
98 evo gold
no bonnet pins. there is a provision for them I think like an outline of sorts. I am doing my new air box on the weekend then I will give it a bit of a clean and take some pics.
- 16bit
98 evo gold
just got a wheel alignment done
Front:
Caster left 5.96 - Caster right 5.39
Toe 0.5 out per side
Camber 2.3neg per side
Rear:
Toe 0.4 in per side
Camber 3.1neg per side
Wait to see how it goes at the club track day on the 5th of march.
Front:
Rear:
Toe 0.4 in per side
- 16bit
98 evo gold
just ordered a sparco 4pt harness for thursdays track day. can't wait!
- 16bit
98 evo gold
harness has arrived and I will be installing tonight!!!! thanks to Peninsula Race gear - great price and service as always.
