Boyracer D1-R
- 16bit
Boyracer D1-R
christ alive. >900kgs and 500nm = skids.
- Boyracer
- MX-5 Encyclopedia
Re: Boyracer D1-R
So it's time for a bit of an update...running as a 2A car was always going to limit where and when I could race it...so it's time for a bit of a change...the turbo engine is heading north and in will be going a pretty hotted up NB8A engine...CAMS, Carillo rods and Supatec pistons are on order...this could be interesting.
Re: Boyracer D1-R
CT's old car was an NA screamer, he might have a few secrets to share.
Re: Boyracer D1-R
oh monster NA motor now!
good work!!
will keep an eye on thread!
good work!!
viewtopic.php?f=73&t=62834
Re: Boyracer D1-R
hows the build comning along mate?
- Boyracer
- MX-5 Encyclopedia
Re: Boyracer D1-R
Block has been machined and parts are organised, head still has to go to get done, buying the 10AE road car has sorta used up some of my play money so it's turned in to a bit of a long term project.
- bootz
Re: Bonnet Vents
Boyracer wrote:The D1-R doing a bit of Doorifto...
I am interested in getting some of those bonnet vents. Are they the Escort Cosworth fibreglass ones?
- Boyracer
- MX-5 Encyclopedia
Re: Boyracer D1-R
We have had a bit of progress with the new engine...Carrillo rods and Supertech forgies, I've assembled the bottom end and now have the head and cams so hopefully it should be built in the next few weeks.
Re: Boyracer D1-R
what sort of power are you looking to get out of this thing?
I dont care that my laces aren't fat or that I'm not even close to flush and I certainly don't want to be the illest!
- Boyracer
- MX-5 Encyclopedia
Re: Boyracer D1-R
I'm guessing about 140rwkw...will see when its together, I have 2 weeks off and all the bits so hopefully will be together soon...the car is very light so it's going to be pretty quick.
I'm also fitting a NB front sub frame and steering rack, and the LSD is coming out and a spool is going in.
Will have a few photos up next week.
Once again thanks to MX5mania for their help with the car.
Re: Boyracer D1-R
get many of the parts from the USA?
- Boyracer
- MX-5 Encyclopedia
Re: Boyracer D1-R
I bought everything from Mania, prefer to know that I'm getting all the right bits and have the support close by.
Finally getting the engine together, the bottom end is a late model 1.8, they have a bit more strength than the earlier models.
OS Giken Clutch and the Supertech Forgies...
- Boyracer
- MX-5 Encyclopedia
Re: Boyracer D1-R
Fitted the NB8A head and engine is in...head has been shaved and ported, inlet port matched and Tighe cams fitted, ARP stud kit and racing head gasket, Maxim Works extractors, have been sorting wiring and plumbing before I fit the inlet manifold.
I probably should have been adding up the hours I have spent and the cost but it's all a bit scary...this is very expensive.
- NitroDann
Re: Boyracer D1-R
[quote="Boyracer"]Well the car is back from MX5mania( thanks David and crew)....unfortunately it made a bit more power than I thought...
about 153 rwkw and about 500nm torque...going to be fun at Wakefield in a few weeks...
This makes no sense. With 153kw and 500nm of torque you be making peak power at 2922 rpm.
So your making the 30psi of boost necessary t make 500nm at less than 3000?
And why are your rods ok at 500nm but no one elses make it past 200?
Sorry I just dont follow how this is possible.
- sliq
Re: Boyracer D1-R
NitroDann wrote:This makes no sense. With 153kw and 500nm of torque you be making peak power at 2922 rpm.
it's boyracer we're talking about. he makes the impossible, possible.
