Stuart & Lisa's MINX
- bruce
- Vehicle: NA8 - Turbo
- MINX
Pretty proud of this
Six laps of Lakeside within half a second while hauling Car and driver in the groove
Lap 5 was a bit slow with a small slide at top of eastern loop
- MINX
Re: Stuart & Lisa's MINX
Awesome man cave!
Can never have enough garage space.
- MINX
Work continued on the Minx Maison today
Found some white paint under the house- win
Built a wheel shelf and utility battery charge station.
Now I just have to sort out the other side !
Looks like a good start. I also have panel lift doors, which kind of sucks for lighting and makes it impossible to hang anything from the roof. Also means I have to be creative with the planned hoist install.
Hope you have more clearance above the door than me, as my lighting choices are limited to flush mount as opposed to normal fluo tubes.
I was extremely frustrated not being able to access my tools at first but judging by the pics, you've already got that sussed.
Re the driveway, steel plate bolted at four corners would be easiest, as mentioned by magpie or break it up and re concrete just as okibi suggested.
I wouldn't mess around attempting to stick new concrete over the existing slab as it will crack and break off a lot sooner.
Just my 2c
Just my 2c
- MINX
Man cave done for now
Now I just have to sort out the gardening, building and painting tools area
That is once I have painted the rest of the house!
- MINX
Brakes work!
Trophies need to be moved into an out-of-reach area if they're in the garage, otherwise they're just taking up valuable space for tools-n-stuff you need access to
- while you may think you have enough space now, you'll soon run out.
- MattR
That's why my trophies are inside in the study.......
- MINX
you must have a massive 'study' Matt !!!!MattR wrote:That's why my trophies are inside in the study.......
Mine don't take up too much space at all, unfortunately [FACE WITH TEARS OF JOY]
- MINX
New addition to our little family
A rehomed 9 yr old Schnoodle called Irwin
First trip in Minx today to the pet barn
- ManiacLachy
Awesome I hope the pup enjoyed the ride. I haven't taken my boy for a ride in the car for a while - he slipped all over the place in the leather seats.
- MINX
Update
Still going strong and back to commuting for new job
Tonne milestone
Tonne milestone
- MINX
163,000
Never happy with the Exedy HD Clutch, so it's gone.
Automotive Plus put in. Light weight flywheel, and Exedy Ceramic Cushioned Button Clutch. Replaced leaky master and slave, added ss line.
All good. Pretty bighty, but pedal pressure is fine, and response is good.
Take offs require a deft touch and throttle balance but nothing we won't get used to easily.
New Prestige top arrived from UK, $950 delivered.
Just need a spare day to fit before Tassie Natmeet.
Stuart
Stuart
Users browsing this forum: No registered users and 45 guests
