Daffy's SE
Daffy
Re: Daffy's SE
Postby Daffy » Sun Jan 28, 2018 8:26 pm
bruce wrote:Well, they have been called a bunch of Ladies!
Fugly ladies at that :?
viewtopic.php?t=73496
ManiacLachy
Engaged
Re: Daffy's SE
Postby ManiacLachy » Mon Jan 29, 2018 7:49 am
Lokiel wrote:You guys are the worst photographers ever, instead of hot busty bikini-clad babes draped over the hood of the car, you've given us crotch-shots of blokes working under the car!
Gina is always invited to show off her curves, but she's been quite shy of late!
Magpie wrote:Lachy did get his shirt off, does that count :)
I had to lie on the ground after the storm and my shirt got soaked and I wanted to dry it a little before getting back in the car. Besides, I didn't hear any complaints!
Gladiator
Re: Daffy's SE
Postby Gladiator » Wed Jan 31, 2018 6:51 pm
Wet T shirt comps at your place now Mark? Why did you let Lachy enter but?
Re: Daffy's SE
Postby Magpie » Wed Jan 31, 2018 9:42 pm
Gladiator wrote:Why did you let Lachy enter but?
he was the youngest!
Daffy
Re: Daffy's SE
Postby Daffy » Mon Mar 19, 2018 7:32 am
A question was put to me recently RE the intercooler details, as I had lost all notes, to look back into required touching base with PWR. The Problem Child’s PWR intercooler is an Areo2 (model PWI 5429 UD) core is 600mm x 196mm x68mm with 2.5 inch bottom outlets.
On install, it didn’t fit past the rails, so mechanic Daz had to modify to fit it by doing a chamfer at both the top corners to get in past the rails, then engineer Ben re-welded the reshaped corners back up. The condenser was repositioned before remount, and we had to angle the radiator a few degrees back at the base.
Daffy
Re: Daffy's SE
Postby Daffy » Tue Apr 10, 2018 3:56 pm
Daffy wrote:........On install, it didn’t fit past the rails, so mechanic Daz had to modify to fit it by doing a chamfer at both the top corners to get in past the rails, then engineer Ben re-welded the reshaped corners back up.
RE intercooler install, said chamfer work.....
Daffy
Re: Daffy's SE
Postby Daffy » Thu Apr 12, 2018 10:52 pm
Service sorted. Some fresh oil, an oil filter change and some new spark plugs. Changing the plugs though isn’t completely straightforward when running motorbike coils, some modification required, via an angry Lathe that ate a $21 spark plug lunch on me!
The iron man PPF brace is still holding rock sold.
Daffy
Re: Daffy's SE
Postby Daffy » Thu May 10, 2018 9:52 pm
Latest (and long overdue addition), I finally got my hands on the famous Beavis Motorsport short shifter.
The install was a breeze, as quick and easy as shown on Brendan’s YouTube vid.
It feels great- sits rock solid in place and snaps into gear like a bear trap. Such a notable difference in the speed of the shift changes. :BROADY:
Now all I need is a quality weighted gear nob..... any suggestions?
beavis
Re: Daffy's SE
Postby beavis » Thu May 10, 2018 10:00 pm
Wooo, looks awesome!
It's such a shame that it's hidden away and you cannot see it!
greenMachine
Re: Daffy's SE
Postby greenMachine » Thu May 10, 2018 10:02 pm
Daffy wrote:Latest (and long overdue addition), I finally got my hands on the famous Beavis Motorsport short shifter.
Voodoo FTW.
Black, round, sits low on the shaft, and mine has no shift pattern - very clean appearance.
:mrgreen:
ManiacLachy
Engaged
Re: Daffy's SE
Postby ManiacLachy » Fri May 11, 2018 9:03 am
Voodoo is too light, IMO. I have one with a shift pattern, which no longer lines up properly, you're welcome to borrow it if you want to see how it feels.
I really like my Moddiction knob, same shape as the Voodoo, but much heavier. No shift pattern, but that's fine I know where the gears are.
Re: Daffy's SE
Postby Lokiel » Fri May 11, 2018 9:49 am
I'm a Voodoo "fanboi", even have one in my SP23.
If your shifter is angled, the spherical shape of the Voodoo knob is better than other shapes since it still feels right (ie. there's no bits that jut out and dig into your palm when shifting due to the modified angle of the gearstick shaft).
I suspect ManiacLachy had tried a heavier knob before the Voodoo knob and preferred it.
The Voodoo knob is heavier than OEM and I haven't tried a heavier knob so I think the Voodoo knob is perfect (ie. maybe I just don't know any better).
The Voodoo knob was designed for MX5s so that's another selling point.
When parked in the sun they get bloody hot so use protection - in your case, I recommend this:
https://www.golfmadonline.co.uk/masters-creative-covers-daffy-duck-novelty-golf-club-headcover-driver-head-cover/
Roadrunner
coyotes after you
Re: Daffy's SE
Postby Roadrunner » Fri May 11, 2018 9:53 am
I put a Skunk2 Gear Knob on my short shifter. Nicely weighted and has a red shift pattern etched into it. Feels really good in the hand.
Made the stiffer short shifter feel easier to change. Made it easier to get into reverse too, something the wife always struggled with.
Highly recommend though it can get blistering hot in summer!
Looks better in real life than in the photos:
https://skunk2.com/accessories/shifting ... b-203.html
MeepMeep
Re: Daffy's SE
Postby Magpie » Fri May 11, 2018 10:24 am
I like my setup...
ImageGear Knob by Eipeip, on Flickr
ManiacLachy
Engaged
Re: Daffy's SE
Postby ManiacLachy » Fri May 11, 2018 10:29 am
Roadrunner wrote:I put a Skunk2 Gear Knob on my short shifter. Nicely weighted and has a red shift pattern etched into it. Feels really good in the hand.
I have one of these on the shelf too (Lokiel was right, I did have a heavy knob before the Voodoo).
Daffy, you're welcome to give this one a go too (though mine is made by Blox, I don't think the Skunk2 branded version is around anymore). I didn't love the way this one fell to hand, but the weight is nice.
Users browsing this forum: Bing [Bot] and 6 guests
