Emily's 04 VR SE
- Aussie Stig
- Stig
Re: Emily's NA6 V-Special Roadster
Ah tol ya you needed dope mags. Righteous.
SPring rate discussion here:
viewtopic.php?f=30&t=53654
Basically the Kings shouldn't be that stiff that you'll be bouncing, My Mazdaspeed springs are probably comparable to the Kings in rate (Kings are progressive and list low and high rates, mine are progressive but only list one rate, so I assume it's the overall average..... basically, mine are slightly stiffer than the Kings average rate)
Anyway, the point is, SPrings like the Kings work well enough on OEM shocks without causing much extra bounce, so on the Billies they should be fine and bounce-free.
(they certainly won't be like Yellowspeeds..... personally I think they're so badly damped they feel like there's a pogo stick under each corner of the car)
You're going to need some guard rolling too with those rims to prevent rubbing - even then they'll probably still be too wide.
My housemate has them on a black NA8 and they do look good - just make sure that when you get pulled over you smile sweetly and plead ignorance to the cop.
Aussie Stig wrote:Ah tol ya you needed dope mags. Righteous.
Rare and legit JDM wheels cant be in the same sentance as 'dope mags' hahaa, but yes they look boss imo.
hks_kansei wrote:(they certainly won't be like Yellowspeeds..... personally I think they're so badly damped they feel like there's a pogo stick under each corner of the car)
I couldnt agree more, I've sat in a couple of cars, NA's and NB's with them fitted, and I was so unimpressed, they felt like shytttt, not sure why they are so popular haha.
Lokiel wrote:You're going to need some guard rolling too with those rims to prevent rubbing - even then they'll probably still be too wide.
Yep guard rolling this week, ppffttttt no way to wide, have you seen what they fit in America? crazy 10" -25 fitments. My 8" +23 will be perfectly fine.
They arent my rims though, thats just a pic of an NA with stock hight/alignment, to show that those sorts of fitment dont go without lowering and neg camber haha.
Mine are a secret
- PaulF
emily_mxV wrote:hks_kansei wrote:(they certainly won't be like Yellowspeeds..... personally I think they're so badly damped they feel like there's a pogo stick under each corner of the car)
2 reasons:
1. $$$
2. "Coilovers brah, hektik"
- Dweezle
I had Bilsteins & Kings on my Malibu and Hated them!!
They crashed their way over bumps.
Smooth, racetrack condition they felt ok, but anything else and it was horrible.
Especially corrugated like surfaces. They just felt like they could never keep up with the undulations.
It was truly awful!!
I went with Yellowspeeds this time around.
When they are set soft they feel like a Pogo stick.
But that is just because the high spring rates are now too powerful for the dampening setting.
Yellowspeeds provide me with a firm and quick reaction, like ride when set quite stiff compared to my Bilstilein/King combo.
The best way for me to explain it is, the bump happens then it is over and the car is not unsettled.
I looked to have the Bilsteins revavled at Heasemans.
This was quite expensive but i was assured they would feel great as they are valved incorrectly for our cars from the factory.
Hence why FatCatMotorsport valve them for your needs.
I never had them revalved.
They just went with the car when i sold it.
I hope your Bilsteins provide a better experiance then i had.
PS- looking forward to seeing what wheels you have bought!!!
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
Oh dear that doesn't sound to good!
Maybe they were worn out or the springs were to stiff/soft?
I hope mine are ok, really would have to be better than my stock set up though, it's gone really soft and willowy.
- NitroDann
Number 1 coilover stuffup.
Setting the damping to minimum.
That will always feel like crap.
I've dríven Luis' car and it didn't feel right but suspected that was due more to setup than anything else.
There are also a lot of Yellowspeed owners who are happy with them. I've got them on my Integra and quite like them - unbeatable for the price really and like Dweezle said, hit a bump, and you move on.
Right now, I've raised the car as I felt it was too low, scraping the underside and tyres as well. With the car higher, I've got a little bit of oscillation, but I think tightening it up one click might solve that...obviously it's not bothering me enough as I still haven't done it.
At the end of the day, they're not going to perform like Ohlins...but I wasn't prepared to spend that amount.
By comparison, my Tein Super Streets ride like stock and I just about max out the adjustment when I go to the track.
- Dweezle
Here is thread i started due how bad they felt.
http://mx5cartalk.com/forum/viewtopic.php?f=30&t=42565&hilit=king+bilstein
I believe a few good points are made in there somewhere ???
The FCM bumpstops will help a lot i think.
I was going to get those.
Jeremy Clarkson
Jeremy Clarkson
Don't worry about the rims, I have 15x8 +4 with 205's on it and don't scrub driving it as hard as I want with 70-80mm ground clearance. Going up gutters is different though, because the pressure is opposite so I scrub, but hey, you have 19mm more clearance and probably slightly better height too. What tires you going with?
I like my girls how I like my cars, topless.
yeah, I spent a long time researching on cr.net with all their fitment threads etc. should be great.
Hopefully a 205 kumho ku31
Emily
No need to give up on the Bilsteins! Read this thread from someone who from all reports had a sweet setup.
viewtopic.php?f=30&t=30330&p=385659&hilit=Bilstein#p385659
Make something idiot-proof, and somebody will make a better idiot.
2007 Limited Edition (back in the saddle again)
- KevGoat
Veloce wrote:Emily
Agree
FCM use Bilsteins on their customised coilovers and I can't recall ever reading a bad comment about their setups whether built for comfort, for the track, or combined! Quality and the ability to revalve/rebuild Bilsteins to one's own specs ($$$ allowing) is what makes them so appealing to so many.
- Dweezle
The key word is Revalving
Heasemans quoted me about 18 months ago $1200 to revalve the 4 shocks.
Jeremy Clarkson
Jeremy Clarkson
