charlie's na6
slug_dub
Re: charlie's na6
Postby slug_dub » Wed Sep 14, 2011 7:13 pm
Saturday! zomg you *are* slow :mrgreen: /me runs!
Good to see you persevering even if you claim injury :lol: :beer:
charlie_91
Re: charlie's na6
Postby charlie_91 » Mon Sep 19, 2011 5:47 pm
Sup guys.
So did a little more this weekend. Finished off the bay apart from a few little things.. Working out exactly what i need and where im gonna get my machining done atm.
I want to get this right. Ill order all my engine parts first then once my old turbo kit sells ill order all the new stuff. Really keen to get a respray as well if its within budget. Once i send my motor off for machining etc it should all come together pretty quick hopefully. Goal date is christmas and to have it run in by the new year.
Fingers crossed :D
charlie_91
Re: charlie's na6
Postby charlie_91 » Mon Oct 17, 2011 4:06 pm
Sup guys..
long time no update huh.. Well there has been a few things happening.. nothing that u can actually see.. yet
So in the last 3 weeks or so i have spent a lot of money buying all the parts needed.
list of parts i have bought so far
Master bushing kit,
mishimoto fan shroud,
mishimoto radiator 3-row 52mm,
pauter machine rods.
Pro-Gram Engineering (5) billet steel main caps,
MiataRoadster main bearing support plate ,
MiataRoadster ARP fastener kit,
Moroso coolant expansion tank,
Wiseco 8.5:1 CR forged pistons with rings set +1.5mm,
ACL bearings rods STANDARD (Race Series), ACL bearings crankshaft STANDARD (Race Series),
ARP main caps studs kit ,
Maruha Motors head gasket for turbo 79mm bores 2mm thick,
Maruha Motors oil pan baffle,
Mazda tie rod ends from R package,
Jubiride flares,
Garage vary front lip,
garage vary canards normal,
garage vary canards extra large
6 speed gear box
Red Hardtop
engine bay bolts
catch can
225/45 15 rs3's
M- tuned fuel rail
Flyin miata big fuel kit
I.d 1000cc injectors
3" custom exhaust
m-tuned re route kit.
There is a few other little things that i need to do/ buy..
- Rebuild kit (seals and gaskets etc)
- stronger Timing belt
- Ceramic coat manifold, turbo rear housing, dump pipe.
- Send block out for machining and balancing etc.
- Respray engine bay and exterior
- Wing lol
- New wheel studs and bearings
- Na8 rear calipers and disks
- New valve Cover with -10 fittings welded on
misc stuff
Hopefully it comes together how i want
dave2221
Re: charlie's na6
Postby dave2221 » Mon Oct 17, 2011 4:21 pm
sounds like its comign together like i want!
plohl
Re: charlie's na6
Postby plohl » Mon Oct 17, 2011 4:58 pm
quite a parts list dude.
Hopefully it comes together quickly for you!
plohl
sailaholic
Re: charlie's na6
Postby sailaholic » Mon Oct 17, 2011 5:10 pm
Nice list, leaves me with a few burning questions. Apologies if you've answered them earlier.
1. Fitting flares and your bbses are up for sale.....what are you going to run, now :-) .
2. No ecu listed there, you staying with the e manage blue?
3. Are you planning to do track or drift work with this new setup?
Hope you get your Christmas wish
charlie_91
Re: charlie's na6
Postby charlie_91 » Mon Oct 17, 2011 5:35 pm
Good questions..
what i was planning to do was replace the bbs with different wheels.. more suited to the application that i want this car to be. I see bbs as more hard park/ euro wheels.. something that wont quite sit with my new setup.
But tbh im not to bothered if they dont sell simple as that. If they do then great i can get new wheels if not then it doesnt bother me :P
Ecu im running is a haltech sprint 500.. i had that installed with the previous setup. I spoke about setting up a car with dual purpose.. something that looks good yet can perform. So thats my plan now.. Have something i can drive around and have fun in and take it to the track for a thrash.
Since a lot of my mates own hondas and see the track regually id like to join in :P
charlie_91
Re: charlie's na6
Postby charlie_91 » Tue Oct 18, 2011 10:42 pm
Update: my rs-3s came in today as well as my m-tuned fuel rail
Also ordered something from japan to :D
plohl
Re: charlie's na6
Postby plohl » Tue Oct 18, 2011 10:47 pm
what do you think of the fuel rail dude? good bit of kit?
plohl
charlie_91
Re: charlie's na6
Postby charlie_91 » Tue Oct 18, 2011 10:51 pm
Hey dude. It seem good. I only got this rail because I wanted the flyin miata one but thats on recall or something and I needed a dual fuel for my bigger fuel system :)
charlie_91
Re: charlie's na6
Postby charlie_91 » Wed Oct 19, 2011 9:17 pm
Update: Stripped the bottom end tonight.. found some slight score marks in the crank so had to cancel my acl bearings order.. Gonna have to wait to see if i need to go oversize or not.
Also got my hardtop in today :D Its finally good to make some progress.. Few more weeks and i think ill have all my parts and my car should be painted by then..
Then its just motor, bushings and ball joints, arp wheel studs, install 2way diff (might change back to a 4:1 instead of 4:3) Then reassemble :D
Jace
Re: charlie's na6
Postby Jace » Thu Oct 20, 2011 4:39 pm
Colour change?
charlie_91
Re: charlie's na6
Postby charlie_91 » Fri Oct 21, 2011 3:43 pm
Nope just staying red on the outside.. but doing a grey engine bay.
Anyways.... my fuel system arrived.. it is a Flyin Miata big fuel kit.
It replaces all the old fuel lines with stainless counterparts, aem fuel pressure reg, dw 300 lph fuel pump, m-tuned dual feed fuel rail and an inline fuel filter :)
This should be more then capable to handle my power and e85. Should be very good indeed.
IMG_2728 by charlie_2011, on Flickr
charlie_91
Re: charlie's na6
Postby charlie_91 » Thu Nov 03, 2011 9:24 pm
Update yay <:D
Few more parts have come in.. Wheels, Flares, hardtop and some canards. All my motor and sussy parts should start arriving next week :D
The car is going in to get a respray tomorrow :) Also picked up new bonnet, front bar, rear bar and boot lid today so it should be looking pretty clean when its done :D
enough talking, heres some pics :D
IMG_3365 by charlie_2011, on Flickr
IMG_3369 by charlie_2011, on Flickr
IMG_3372 by charlie_2011, on Flickr
IMG_3367 by charlie_2011, on Flickr
ak_perth
Re: charlie's na6
Postby ak_perth » Thu Nov 03, 2011 9:32 pm
Great wheels, i'm excited for you about how it's all going to look! :D
