A sleeve, never heard of that? Sleeve the crank, or the seal itself? You are not pressurising the crankcase are you, IIRC there have been cases on MTnet of turbos pumping oil out of crank seals?
rascal wrote:Do you have any pics of the cam cover setup? Did you put any mesh inside the cover or just enlarged the holes?
I have done a single tiny hole mod out to 10mm and factory exit tube to catch can and blocked PCv side, but I think I need to do more. Thinking of two an10s .
greenMachine wrote:That sounds like progress!
Lack of traction may be due, in part, to cold tyres? A couple of warm-up laps may make a big difference, I presume not an option this time?
Users browsing this forum: Bing [Bot] and 12 guests
