The Red Green Machine
PaulF
Re: The Red Green Machine
Postby PaulF » Mon Mar 10, 2025 7:50 am
greenMachine wrote:He is hissed off, the engine has to go back to the bloke who built it, he didn't do the necessary machining for the new non-standard rear main bearing oil seal - could have been worse, the reason he rang was another engine he built using the same seal has just ruined a brand new, imported crank, for want of a little machining :shock: :cry:
So the engine builder called your neighbour and asked him to send it back because he'd realised his mistake? And presumably he's fixing it without charge. Honestly, in today's aftermarket that's a high level of service and integrity.
greenMachine
Postby greenMachine » Mon Mar 10, 2025 8:23 am
That's how I understand it. It is a small community, and word of mouth is probably pretty important. That engine is still untouched, never run, relatively simple job to rectify.
The broken one not so much, if the same offer applies - likely got metal shavings all through it, might/probably need a new crank, basically start the rebuild all over again. Costly for someone for sure!
:mrgreen:
greenMachine
Postby greenMachine » Mon Mar 17, 2025 1:07 pm
Said goodbye to the RGM this morning, waved goodbye as it drove off down the road ... :cry:
Next time I see it here it will be resplendent in its new paint job, hopefully in a couple of weeks or so. 8)
:mrgreen:
PaulF
Postby PaulF » Mon Mar 17, 2025 1:55 pm
Exciting times!
The American
Postby The American » Wed Mar 19, 2025 8:59 am
That’s a bit exciting. It’s amazing what fresh paint can do
ManiacLachy
Engaged
Postby ManiacLachy » Wed Mar 19, 2025 10:09 am
Fresh paint! You know your build is coming together when it's time for fresh pain!
Did you make sure to take a before photo for comparison?
greenMachine
Postby greenMachine » Wed Mar 19, 2025 8:24 pm
ManiacLachy wrote:Fresh paint! You know your build is coming together when it's time for fresh pain!
Pain?! PAIN :shock: :cry: :shock: Have you had a car/parts painted recently - it is going to cost me my first-born, unless someone tips him off and he goes into hiding. Really, it is a small sacrifice he should make for his old man, right?
I'm sure there is one somewhere. Better be, I'll need something to look at every 15mins to reassure myself it was all worthwhile ...
:mrgreen:
greenMachine
Postby greenMachine » Sun Apr 20, 2025 11:11 pm
Picture perfect! Clearcoat rot gone, sparking Velocity Red perfection!
Now for the wheels ...
:mrgreen:
Postby 93_Clubman » Mon Apr 21, 2025 11:26 am
Looks like great paint job GM!
ManiacLachy
Engaged
Postby ManiacLachy » Mon Apr 21, 2025 4:28 pm
She looks as good as she goes now! Very nice :NB8B:
Postby KevGoat » Mon Apr 21, 2025 11:45 pm
Nice!
The American
Postby The American » Tue Apr 22, 2025 1:07 pm
Looks the goods Ed!
greenMachine
Postby greenMachine » Tue Apr 22, 2025 5:06 pm
Thanks everyone!
If I'd had my druthers I'd have done it in something closer to Soul Red, but it had to match the bits that can be seen when you open the doors and bonnet - so that settled the colour choice, there was no choice really. It has come up very nice, but photos don't do it justice.
The front wheels are the problem, at least in that set. They show the results of my lack of appreciation of the significance of the differences between the R10 and R12 compounds. The R10's dust comes off easily, and does not set hard. The R12 dust needs to be removed quickly or is sets. The front ones will, I suspect, need to be chemically cleaned and probably repainted. The rears are relatively good, but can be improved. I am getting the names of wheel people, and seeing how much it will cost.
Depending on the outcome, it may be more cost-effective just to bite the bullet, buy a new set and sell these off as-is, for track work. Oh, and stay away from the R12s.
:mrgreen:
greenMachine
Postby greenMachine » Mon May 12, 2025 10:51 am
Speaking of the fronts, got some new wheels, put the car on the hoist for some work, take the wheels off to swap tyres to the new rims, and what do I find ...
WTF, I have absolutely no recollection of ANYONE telling me about this! :shock: A straight edge shows only the merest hint of a bend, so it is not clear to me that any significant issues arise, beyond the obvious that it needs replacement, and 'how the hell did that happen?". On the latter, the only thing I can recall is the damaged wheel on that corner when I hit an unnoticed 'thing' on the road at decent speed, as far as I can recall it was the rack end on the car when I bought it. I have a couple of spare racks, so I can cannibilse one of them for the necessary piece.
Which leads to the other discovery ...
What has caused this? It is on the sidewall more than the shoulder, suggesting that it is something other than toe or camber, all bushings and ball joints seem ok, no sign of rubbing anywhere, and both fronts seem equally affected.
I was to have a new alignment done, so I will have him look at the front end before he does the alignment, in case there is some work to be done there to remove/replace whatever is the problem.
:mrgreen:
Postby bruce » Mon May 12, 2025 11:12 am
Someone wrote Bent and forgot to tell you. Must have been during a wheel alignment?
Users browsing this forum: No registered users and 24 guests
