Is it Friday yet?
Is it Friday yet?
What about now?
How much longer?
smy0003 wrote:Any news, Steve?
Sent from my LG-H815
Cus wrote:Is it Friday yet?
Is it Friday yet?
Is it Friday yet?
What about now?
How much longer?
Is it Friday yet?
Is it Friday yet?
What about now?
How much longer?
rossint wrote:Are the pins seated in the options port plug properly? I had a problem with my boost solenoid not going when it got to the tuner because the pins weren't quite in tight enough. I ended up having to pull them through from the front of the plug to seat them.
smy0003 wrote:The EBC solenoid worked in my car, if it's cactus shoot me a PM and I'll refund you
rossint wrote:Glad you found the problem. What turbo do you have? I've got a TD04 on mine, I asked the tuner for 150kw if he could get it safely. Got it back making 150kw at 10psi, he said he didn't need to do much to it to make that. I have my boost controller on a switch so i can run 6psi gate pressure which gives me about 125kw.
rossint wrote:1.6 with standard internals. I do have mild cams in it from my pre turbo days but not sure if they make much difference or not.
