- MattR
Well for an extra couple of hundred dollars to the total cost why wouldn't I????
Here are some stats on the cars behaviour (as measured by VBOX Performance Tools)
0-100 takes 7.10 secs and 115.69m
110-35 takes 4.49 secs and 77.6m
The front has a massive squirm under heavy braking, however the car still needs to be corner balanced since the build so I will do some more heavy braking once this is done. The rear rose by roughly 35mm in the brake above, however the front sensor was offline (another issue) so no idea on the front. I did lift the front end by 10mm the other day (sick of the scraping) and this could have resulted in the unbalanced feeling of the car.
During this time of year is not the best time to be testing a car, even within the speed limits there are just way too many police around.
- MattR
With regard to the squirming under brakes, if you have played with the front end set up that could explain it.
Wait until you have corner weighted the car again and reset your ride heights. It could be a matter of adjusting the bum to stop it coming up in the air, or adjusting the front to control the pitch and dive under brakes, that may also then affect the general behavior of the car on the road.
Next we can look at is the brake balance between front and rear, maybe get the rears to do a little more work, I can't remember if you have adjustable brake bias or not. After that, well you can play with pads and what to use front and rear.
And I can't let it go, remove the brake booster, it won't change what's happening with the braking at the moment, but it will give you more room, and without the vacuum assistance the pedal effort is higher, but you do get a lot more feel at the lock up point, and it is easier to release the small amount of pressure you need to than on a boosted system.
- speed freak
I can vouch for that 0-100 time. I popped over to Marks place yesterday to try some wheels etc. While I was there I had to have a good look at his NA again now with the newly fitted engine. I was lucky enough to be taken around the block in it sitting in the passenger seat, then I was even more lucky to be offered a drive!!! It was one of the best driving experiences Iv had and Im still smiling about it. The acceleration is instant and brutal as soon as you floor it your pushed back in the seat and your off, and that INDUCTION ROAR!!! Its addictive put it that way lol its well worth all the time and research, its definitely paid off. Well done to Automotive Plus too they built one hell of an engine to go in one hell of a car. Great fun, thanks again Mark.
Thanks MattR for the advice, with the exception of the booster delete I have taken notes. There is no adjustable bias however this is on the agenda as I still believe that the rears are doing less work than they are capable of.
I now have the brake pressure valve installed (front) so I can now monitor the pressure when braking. Plan is to find out when it looks up and then get used to that point. Then when looking at the data from a track session I can see if I was braking at the cars limit (tyre dependent).
Speed Freak I'm glad you enjoyed the drive, now you have some ideas to use on your car, not just new wheels
I'm a pretty bloody crap driver, this is just my 2 cents.
My car moved around a lot under brakes, I did try adjusting the brake with a little more to the rear, worked a little. It's a light car, if you are going to jump on the brakes, it will and should move around. If it doesn't you are not driving hard enough.
A mx5 is an mx5, there is only so much you can change, I.M.O. it's not a F1 car that you can make 100 different changes, you are very limited to the set dynamics of the car.
Once you have the basic set up, you are only talking 100th of seconds, with all the other parts. I.E. corner weighting and the rest of that BS.
If I was you, I would set the car up with a basic set up, then take the car to the track and beat the snot out of it and don't change a bloody thing for a doz or so track days. I.E. stop f#%king with the car.
BTW I really like the car. Sorry if I sounded like a c#&t! Also I hated the booster delete!
Regards
Regards
toppertee wrote:If I was you, I would set the car up with a basic set up, then take the car to the track and beat the snot out of it and don't change a bloody thing for a doz or so track days. I.E. stop f#%king with the car.
Regards
That is the plan now, I have a few minor issues to sort out, however there are no more fundamental changes left to do. After a few more hard braking sessions the squirm seems to be less than the first experience and that could be down to getting used to it. A corner balance will still be done in the next week or so.
Another brake test today and it took 58.05 m to go from 110 to 30 kmh (Racelogic GPS) this time with the brake sensor and front ride height sensors working.
The red mm numbers are the front height and the green mm are the rear height. These heights are relative and you look for changes from at rest. The black line is the front brake pressure and I did not lock. Plan is to do more brake testing and see at what pressure the brakes lock.
Well, I guess this is the final list of the mods done on this car.
Engine/Engine bay:
Haltech PS1000 ECU
COP's
NB8 Block (Toda 85 mm pistons, Toda 0.8mm head gasket, Toda timing belt, Carrillo Super A-Rod, balanced lightweight flywheel/HD clutch/crank, Main Bearing Support Plate upgrade, ACL Race bearings)
NA8 head (flowed, port matched, Toda 288 deg in/ex cams, 10mm lift, titanium springs, 1mm oversize valves, exhaust valves to suit E85)
11:1 compression
Toda adjustable cam gears
36 tooth trigger wheel
Racing beat header/exhaust (full front to back)
Jenvey ITB's http://www.compsystems.com.au/index.php/en/products/engine-control/throttle-bodies/kits/mazda-itb-kits/mazda-mx5-1-8l-na-itb-kit-21-detail
725cc injectors
Tomei fuel pressure regulator
Custom (MX5 Plus) vacuum lines from ITB's
Custom (MX5 Plus) coolant reroute
Peterson's Remote Relief Valve http://www.petersonfluidsys.com/pump_acc.html
Toda oil pump gears (oil pressure control shimmed so it no longer functions)
Accusump accumulator http://www.accusump.com/accusump_units.html
Custom oil catch can and breather lines(MX5 Plus)
PWR radiator/oil cooler combo http://pwr.com.au/#/view=products/st=Other%20Car%20Radiators/sb=Mazda/ Part number PWR5119. Complete with custom (MX5 Plus) shroud and 2 x SPAL fans.
Radiator cooling panel
Custom (MX5 Plus) oil lines
Oil filter relocation
Air con removed
Power steering - depowered
Cartek coolant alarm (rigged up to a 110 db alarm and warning light http://www.cartekmotorsport.com/CARTEKCoolantAlarm.html and http://www.autometer.com/cat_accessoriesdetail.aspx?vid=134)
Cartek isolator (http://www.cartekmotorsport.com/tech-info.html)
Driveline
6 speed box (built for up to 400 Nm of torque)
MiataRoadster short shifter
4.1 Torsen diff
NB8B brakes
NB8B proportioning valve
Braided brake lines
Brake/clutch master cylinder combo (inc. custom (MX5 Plus) brake lines)
Trackspeed Engineering Brake Ducts (http://trackspeedengineering.com/product_info.php/products_id/118) as well as custom (MX5 Plus) ducting from GV lip.
4 sets of rims (8 x 6UL's 15x7, 4 x Advanti Storm II's 15 x 6.5 and a normal set 15 x7's)
R888's, Dunlop Direzza 03G, Federal 595 RSR's and set of normal road tyres
Suspension
BC Racing ER's
Butterfly brace
Rear strut brace
Front strut brace (inc brake brace)
Brake Cylinder Brace (no longer installed http://omgpham.com/store/performance/brake-cylinder-brace.html)
24mm adjustable front sway bar (Whiteline)
19mm rear sway bar adjustable (Whiteline - not installed anymore)
949 Racing adjustable end links
Super-Pro front Eccentric Kit (allows up to an extra -3 deg camber)
SRI Rear Upper Adjustable Arms (allows up to an extra -3 deg camber)
Corner balanced
Exterior
949 Racing FRP GTC-200 rear wing
Jet Stream Rear Diffuser (http://rev9autosport.com/jet-stream-rear-diffuser.html)
GV front lip, GV bonnet, GV front/rear wind deflectors (http://www.tetsuyagarage.com/varyfs.htm)
Custom splitter
KazeSpec Engineering Heim Rod Front Splitter Mounting kit (http://miataroadster.com/kazespec_engineering/kazespec_engineering_splitter_hardware_kits/kseshk/i-1680573.aspx)
Carbon fibre roof scoop (http://www.shop.cartel-aus.com/Carbon-Fibre-Roof-Scoop-DWSI022.htm)
Project G Vented Wing Window w/ Pop Vents (http://www.projectgla.com/gvents.html)
Carbon fibre side mirrors
Pitcrew racing single wiper
Dapper HID Projector headlights (http://miataroadster.com/dapper_lighting/dapper_lighting_7_hid_headlamp_kits/dappercp6024rhd/i-1680794.aspx)
Custom blue/silver paint
Rain light (https://www.pegasusautoracing.com/productdetails.asp?RecID=5603)
Smoke indicators (front)
Tow hooks (http://garagestar.com/shop/tow_hook.html)
Offset License Bracket (http://omgpham.com/store/exterior/number-plate-bracket-offset.html)
Hardtop Rain Rails (http://omgpham.com/store/exterior/hardtop-rain-rails.html)
Interior
MX5 Plus Tallboy roll bar
Shift-i shift light (https://ecliptech.com.au/shift-i/)
Custom gauge faces (http://revlimiter.net)
Quick release
Mono D type steering wheel
Terraphone intercom
Single warning light if oil or water goes over 120 deg c (http://www.autometer.com/cat_accessoriesdetail.aspx?vid=134, http://www.longacreracing.com/catalog/item.asp?id=383&catid=11 and http://www.longacreracing.com/catalog/item.asp?id=384&catid=11
Coolant alarm light (url]http://www.longacreracing.com/catalog/item.asp?id=384&catid=11[/url]
Rain light switch (http://www.cartek.biz/CARTEKMOTORSPORT/FiARAINLIGHT.html)
Innovate Data logging (4 x EGT's, oil/water/2 x air intake temps, fuel/oil/brake pressures, RPM, wheel speed, accel/side G force, steering input, AFR, TPS). LMA-3, SSI-4, TC-4, MTX-L: Wideband Air/Fuel Ratio Gauge, MTX-D: Oil Pressure & Temperature, MTX-D: Water Temperature & Battery Voltage and DL-32 daisy chained. (http://www.innovatemotorsports.com)
2 x Sparco Sprints (and harness to suit)
VBOX Lite camera (with micro module) (http://www.vboxaustralia.com.au/Video%20VBox%20Lite.html)
Hardtop Brackets (http://omgpham.com/store/interior/hardtop-brackets.html)
Radio DIN Panel (http://omgpham.com/store/interior/radio-din-panel)
Custom Gear Knob (http://omgpham.com/store/custom-gear-knobs.html?filter_name=gear)
Leather Door Pulls (http://omgpham.com/store/interior/leather-door-pulls.html)
Fire extinguisher
Engine/Engine bay:
Haltech PS1000 ECU
COP's
11:1 compression
725cc injectors
Air con removed
Driveline
4.1 Torsen diff
NB8B brakes
Braided brake lines
Suspension
BC Racing ER's
Butterfly brace
Rear strut brace
Corner balanced
Exterior
Custom splitter
Interior
Quick release
Terraphone intercom
Fire extinguisher
- MattR
You forgot to mention the soon to be done brake booster delete.....
Glad the car is getting to what you want it be Mark.
Now the development mods start
MattR wrote:Now the development mods start
Now working on driver modification, that includes but not limited to weight reduction.
Holly sh*t. I knew you had put some serious gear on but seeing it all in one lists is crazy!
Can't wait to have a good look over it.
sailaholic wrote:Holly sh*t. I knew you had put some serious gear on but seeing it all in one lists is crazy!
Just DON'T add a $$$ column to that list
Lokiel wrote:Just DON'T add a $$$ column to that list
Unfortunately I don't need to do that as I have kept a file on all the costs, I just keep it hidden from my other half...
Well the car has been corner weighted (drivers weight in the car, tyres at 31 psi, half tank fuel)
The new engine has seen the car shed 26.5 kg!
LF 285.5 RF 314.5
LR 260.0 RR 298.0
49.6% cross weight.
Heights (mm) at the pinch welds
LF 125 RF 117
LR 131 RR 125
Splitter height of the ground is 93mm.
I have a feeling that the front will scrape again as the RF Has been lowered 14mm and the LF 3 mm, plus there is now 6mm rake (rear to front) whereas before there was -4mm (rear to front). However I did adjust the front higher before the track day with no regard for corner weights, it was a stab in the dark. Hopefully this may help with the squirm under heavy braking.
Tomorrow's job is to take the preload out of the sway bars and tighten everything up. Plus I'm going to weight the stock (no PS) NA6 I have.
For info the starting numbers were
LF 294.0 RF 305.5
LR 247.5 RR 310.5
47.8% cross weight.
LF 128 RF 131
LR 124 RR 127
LF 285.5 RF 314.5
LR 260.0 RR 298.0
49.6% cross weight.
LF 125 RF 117
LR 131 RR 125
LF 294.0 RF 305.5
LR 247.5 RR 310.5
47.8% cross weight.
LF 128 RF 131
LR 124 RR 127
- plohl
1157kg is pretty heavy
With the squirming under braking, have you looked at your shock settings? Might be getting too much weight transfer to the front.
plohl
plohl
