Andrew's '93 NA6 - KL V6 swap
- plohl
- Beelzeboss
- Vehicle: Non MX-5
Re: Andrew's '93 NA6 - KL V6 swap
Thanks Plohl, so glad that it actually started first go. That NEVER happens!
The joys of converting a FWD engine to a RWD layout, today I made the heater hard lines. I decided to do them in aluminium to practice TIG, save weight and because they look better than steel
I'm not sure whether to paint, polish or leave them as is.
I still have to make a couple of clamps to hold them which will bolt to either the chassis or the valve cover.
All that's left to do in the cooling system is to block off a couple of unnecessary lines.
- Beelzeboss
- Vehicle: Non MX-5
I tried to bend it using sand and heat but it broke before it got to 45 degrees
It's only 1.6mm wall, maybe thicker tubing would be better for bending.
It may have been covered before, but what are you doing in terms of a front swaybar? Also, what other chassis mods are you doing to handle the increased power?
- Beelzeboss
- Vehicle: Non MX-5
I've got an adjustable signature swaybar from that Mania group buy a while back, no other chassis mods planned. The V6 engine is actually lighter than the B6 with A/C and power steering (the front suspension sits about 5mm higher than before) and it's located further back than the B6 so extra weight isn't a problem.
What do you normally need do to the chassis for ~100rwkw?
Oh, here I was thinking it was heavier and with more than 100kW
Does the front swaybar have enough room at the front there; it looks a bit right from the pics?
- Beelzeboss
- Vehicle: Non MX-5
mitch_f1 wrote:Oh, here I was thinking it was heavier and with more than 100kW
The swaybar is pretty close but there is room. From memory I think there's about 25-30mm between the front pulley and the swaybar.
- Vehicle: NA6 - Turbo
Well done love all the diy'ness in your build. The water neck that you welded on, do you have a bead roller of some sort or was the pipe already like that?
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
- Beelzeboss
- Vehicle: Non MX-5
Thanks rxmx, I don't have a bead roller but I made a simple tool which puts the bead on the end of the tube, I'll take some pics of it tomorrow. It's very easy to make and produces an average bead on the end of the pipe. It was made from scrap with a hacksaw and the welder, it's very simple.
haha awesome, it does the job very well
- NitroDann
A proper bead roller is one of my next investments, Id find it hard to put a exhaust clamp/pliers bead on a pipe and then charge someone for it.
Beelzeboss wrote:it's going to be unique and (I hope) one of the best sounding MX-5 around.
Not wrong there!! To date one of my favourite sounding cars!!
Dann, probably not for large scale use but would be handy to have in the garage until the need arose to go out and buy one.
Engine sounds nice
Engine sounds nice
May only have 100rwkw, but will have excellent torque in the light body. It will feel like a totally different car. Great conversion.
