Nevyn72 wrote:Ian, what was the source of the temp reading?
Factory sensor via the MS or aftermarket sensor located where?
Are you using the Tridon high flow thermostat?
Yes factory sensor and the high flow tridon.
billybunter wrote:nice job fitting the new soft top - I believe it's not an easy task to do and complete
IanR wrote:NitroDann wrote:Do you think a reroute is in order Dann?
bear2230 wrote:We are working on a Aussie made venting system at the moment.
Expect to have laser cut prototypes this week as well as a mounting template similar to what's available from OS
Richard.
Nevyn72 wrote:NitroDann wrote:89 at the front is probably 93 at the rear where the sensor is.
If you want cooler highway temps run a lower temp thermostat or a reroute.
I thought previous experience (Roadrunner, but I could be mistaken) had found the coolant was actually hotter at the thermostat exit point to the radiator than at the back of the engine where the factory temp sensor is located.
IanR wrote: delete some of the unnecessary coolant lines (see who bites)...
beavis wrote:IanR wrote: delete some of the unnecessary coolant lines (see who bites)...
I'll bite.
They're all unnecessary with the exception of the ones between the motor and the radiator.
