My era of MX5 ownership! Twilight Blue NB8A
Re: My era of MX5 ownership! Twilight Blue NB8A
Brilliantly!
the autocross was basically a mini racetrack on dirt, so VERY slippery (interesting feeling having the car suddenly slide from compression lock!)
very much a test of smoothness and throttle control.
the Motorkhana was great too, very sliipery (it rained the night before) but that just made it more challenging. Still fairly rubbish at it, but I just need more time to learn the courses and also practice the actual car control parts.
Lowered pics.
Before and after:
Before and after:
- rupewrecht
- Vehicle: ND - Supercharged
MUCH better
jdmparts.rupewrecht.com
Sourcing your not quite overnight parts from Japan
mostly thanks to you good sir!
- bensale
Very nice Nick..! It's the height they should have been from the factory, not too low but low enough. Look forward to seeing it in person on Sunday..!
www.othersideproductions.com
Thanks ben!
Sunday, I presume you're coming down to packenham to have a go?
- bensale
Yep..! =) I've convinced my parents to come down and enter too!!! Should be great fun =)
Motorkhana done and dusted, well.... not dusted.... mudded!
so, it was freezing and WET.
the morning had some slow times with doing courses on wet grass, but it served a great purpose of letting me feel the car slide etc in almost slow motion. Great practice!
as the day wore on, the grass got chewed up, and we were eventually running on mud... really sloppy mud. I almost got bogged during a run!
at about lunch the day was called off, courses were too wet, and we were slowly getting rained in (the driveway was mud too, and as a result we basically spent the next few hours getting those with a 4x4 to tow everyone free to the main road)
there are a few photos of the day up on Ben Sale's Facebook page.
and a today update:
picked up my 949 nuts from James today.
got they're awesome, they are just an amazingly over-engineered piece of work!
also there's a story in this Month's MXTRA about the Deni motorkhana trip!
Nothing much lately, been getting used to the new lowered height.
the poor muffler has taken a bit of a beating
it's now scraped all on the bottom
and the other day my car had a birthday!
Happy birthday!
I'm still thinking of a gift to get her.
Happy birthday!
- Pamex
A water pump full of champagne. :p
Mazdaspeed Champagne?
also, STALKER!!!
also, STALKER!!!
- Pamex
I know what I'll get you. A Mazdaspeed sticker. One of the massive ones.
You will stick it on your windscreen otherwise your girlfriend will think you don't like it and will cry because she thought you'd really, really like the gift.
You will hang your head in shame.
Then we will mock.
Mock, mock.
:p
Back on topic, HAPPY BIRTHDAY QUINCE!
Then we will mock.
Mock, mock.
:p
Ok, now with a new job under my belt I once again have an income, and it's also nice than at the old job. WIN ALL ROUND!!!
this can only mean one thing....... BUY MORE CAR STUFF!!!
anyway, sending the car in on thursday morning for a new set of tyres and an alignment.
uncertain on alignment settings, been doing a little reading and thinking I'll go with Lanny's alignment.
Front
Caster: 5 deg
Camber: -1.20 deg
Toe: 0.075 deg in
Rear
Camber: -1.75 deg
Toe: 0.075 deg in
seems like a nice compromise between the daily run and some fun. (also a smooth one, not a fan of the rear being super twitchy like it is atm)
edit:
tyres are going to be Toyo Proxes 4 in 205/50/15
little bit wider to fill the guards, and also the change to rolling diameter will correct the speedo and give me 5mm extra height to get the muffler over the magical 100mm mark!
Front
Caster: 5 deg
Camber: -1.20 deg
Toe: 0.075 deg in
Rear
Camber: -1.75 deg
Toe: 0.075 deg in
edit:
ok, stuff that's happened since the last update....
more motorkhanas which have been fun, although I keep losing my way on the courses and stuffing up big time.
anyway, the tyres and alignment were fitted/done. Loving it, I went with Bensale's settings which are a brilliant compromise for the road.
I also had the timing belt and water pump cahnged the other day, which was good to get done.
As it turns out, the timing belt had already been changed by the previous owner at some point, odd since the car only has 103,000km on it....\
regardless, I'm now set for another 100,000km.
one otehr thing the shop found was that my water pump was stuffed, the impellor had some play, the pump itself was leaking, and the main water inlet/outlet was basically blocked with crusty old coolant residue.
so the engine is now feeling great!
however, after the thrashing at Bendigo on the weekend I've developed a new issue............ epic clutch slip.
So I'm limping around until I can book in for that to get fixed.
going to just go with OEM equivalent, probably Exedy.
