Magpie wrote:What grade bolts did you use?
With respect to 'welds may weaken the metal' this is not a true statement. It would be a case of picking the right weld/welder (coded welder) for the task.
The weld idea was still on the cards- but Ben was only going to run with it as option 2, he was just getting conflicting opinions over how welding may effect the frame- per fabricated products like the track dog brace used bolts, so I'm guessing thats why he ran with this idea just to be on the safe side- I'm in Sydney at the moment, but I'll get a proper rundown when I pick it up tomorrow. The bolts are grade 8. (I'll be picking you brain soon too RE prepping the car for track days- if thats ok!!)
ManiacLachy wrote:Is that a new PPF with a brace, or the old PPF repaired and braced?
The diff carrier arms would be fine with poly mounts, even with your power.
Its a new (or I should say second hand) PPF that i got from GCMX5 (cheers Greg
I'll see how it goes without changing the mounts at this stage. I most likely will change them when I can look at doing some track days next year- I'll have to start thinking more about the suspension, brakes and cooling before then. (Ps, my wife told me the visor blanks arrived in the mail today- thanks again mate!)
StanTheMan wrote:its missing the bolt on the spacer.......
Everything is now bolted in- the pic's I posted are before Daz finished the job!
