nitrodann wrote:Dont forget to put anti galling paste on th Vband clamps nut, then tighten the clamps together hard before welding, in the correct orientation to make sure they dont warp.
Im serious aboiut the anti galling paste too.
Cheers Dann, I'll definitely do that. I've never used v-band clamps before.
Today I got my MX-6 exhaust system adapted to the MX-5. It was a bit difficult as every component in the system is much bigger than the original.
I put the muffler as a centre exit because it simplified the pipework. The cat and resonator are unmodified, I just had to weld new hangers onto everything and join the rear muffler to the resonator.
Unfortunately I didn't take progress photo's so here are some bad pics of under the car
I welded some new hangers onto the tow hooks to support the centre exit muffler, they seem to work really well.
And, brace yourself, one of how the muffler looks from the back of the car
I also put in the rear coilovers at the recommended height setting to see how low it would be. The new swaybar isn't connected yet.
Not much clearance under the muffler, it hangs a bit low because it's massive.
