Wazman's NB8a
wazman
Wazman's NB8a
Postby wazman » Fri Dec 25, 2009 11:28 pm
7psi is definately fine for daily driving..... but i def need more power if its going to be a competative street class slider.
I also picked up a pair of 8kg rear springs that i will throw in for drift track days. That should help with even tyre wear and slide ability.
Oil temps have gone up 10 deg on the highway :| guess anb oil cooler is on the cards sooner than i expected :roll:
14 psi sounds a bit hecktic for a stock motor.....i used to run 18 through my stock sr20's, but they had metal head gaskets installed.... and sr's have the oil squirters under the pistons.....I've never seen inside a BP 1.8 so i'm a little uncertain as to how much they can take before they let go.... I'm thinking 7 for the street and 12 for the track atm.....But i will let the knock sensor be the judge of that :wink:
ilovedrift.com
lightyear
Infinity & Beyond
Wazman's NB8a
Postby lightyear » Sat Dec 26, 2009 7:17 am
lightyear your numbers look pretty high.[/quote]
The only way to find out for sure is to have a race. I don't really car about the numbers on the dyno, as long as the car has a good tune and is running at it's best for the setup i have.
Wazman's NB8a
Postby Okibi » Sat Dec 26, 2009 12:47 pm
Sasso wrote:...why not just run both 12psi, if the tune is safe its safe, if it doesn't blow up on the track its not going to on the street....
I see what you mean, most of the time you're off boost anywy but extra power would put more strain on the drivetrain and cooling system more often, dropping the boost might make these last longer as well as Waz's licence.
wazman
Wazman's NB8a
Postby wazman » Fri Jan 08, 2010 1:15 pm
I am just running a bleeder valve as of yesterday. Trent at Status re tuned the car and here are the results. The red line is my old tune on 7psi and the Yellow is the new tune 8)
160kw at the wheels on 10 psi :twisted:
The car skates 3rd ! Feels better than my old nissan 180sx that had 220kw atw ......without the lag of the big turbo. Super happy with it.
ilovedrift.com
Wazman's NB8a
Postby Jeo » Fri Jan 08, 2010 1:53 pm
Phwor, that's a bit of a difference!
Wazman's NB8a
Postby Okibi » Fri Jan 08, 2010 4:04 pm
Nice work :mrgreen:
bensale
Wazman's NB8a
Postby bensale » Fri Jan 08, 2010 5:09 pm
WOW! :shock: Have fun :mrgreen:
www.othersideproductions.com
rjr666
Wazman's NB8a
Postby rjr666 » Sun Jan 10, 2010 3:35 am
Going to need to invest in 6speed box or the qauife scynro set with that much power. expect it to bust at some stage.
I need a sponsor
dorifta
Wazman's NB8a
Postby dorifta » Sun Jan 10, 2010 11:38 pm
Sif 6 speed box.. Go ca18 5 speed ($100) + custom bell housing you can afford to pop a box every month!
Wonder if rb25 boxs will fit.. Lol
get busy living or get busy dying
wazman
Wazman's NB8a
Postby wazman » Fri Jan 15, 2010 10:18 pm
Hi all,
I just spent the afternoon finishing my coolant re-rout DIY mod.
Here is a link as i posted it in the "technical section"
http://mx5cartalk.com/forum/viewtopic.php?f=76&t=40239
I am still working on an oil cooler and hopefully will pick up a flywheel this weekend. I want to make sure the temps are all under control before i start thrashing the crap out of it at the track.
Cheers wazman
ilovedrift.com
wazman
Wazman's NB8a
Postby wazman » Sun Jan 31, 2010 2:50 pm
Finally got around to putting in the clutch. After the stock one started slipping bad.
So up the car went and out came the exhaust, tail shaft, braces etc......anything that i thought would be in the way.
I removed all the center console as well.
The stock 1.8 flywheel on the right.....shows the difference in contact area.
In with the new (new second hand, Thanks fatty)
The clutch dosn't slip at all..... even with some mid corner kicks at sandown on sat. Pedal is slightly heavier.
ilovedrift.com
wazman
Wazman's NB8a
Postby wazman » Sun Jan 31, 2010 3:03 pm
A friend of mine was getting his roll cage painted a fancy colour at DT panels in sprinvale and i was lucky enough to be able to throw my cam cover in with it.
Its ment to be "Greddy" brake gold with glitter :|
ilovedrift.com
wun911
Wazman's NB8a
Postby wun911 » Mon Feb 01, 2010 12:55 am
Respect to the dude that installs his own clutch especailly on jack stands!
If the gear box is still out the only recomend upgrades that I would have done while I was at it, is the engine mounts and the ss clutch line. (friggin pain to do when the gear box is back on the car)
Hrmz that clutch cover plate looks familiar looks the same as ryan's clutch...
Is the cam cover powder coated??
Im wondering if powder coating can withstand heat from calipers???
every ounce counts
silvermiata
Wazman's NB8a
Postby silvermiata » Mon Feb 01, 2010 10:06 am
Post subject: Wazman's NB8a Reply with quote
:shock:
i would be s*itting myself trying to undo those tight bolts under a car raised half a meter by 4 jackstands :)
Sean
Wazman's NB8a
Postby Sean » Tue Feb 02, 2010 12:48 am
silvermiata wrote:i would be s*itting myself trying to undo those tight bolts under a car raised half a meter by 4 jackstands :)
Jackstands and chunks of wood :twisted:
