M1474 wrote:If you haven't had your alignment yet fit your coilovers first.
Agree. Just wasted your money and time as you need to do another alignment after you fit the coilovers.
bootz wrote:What sort of sway bar did you install?
I assume that it was a beefier front one, like the racing beat.
bootz wrote:So are you going to go with the standard endlinks, or have you fitted adjustable ones from FM?
Lokiel wrote:Does your brake booster -> intake manifold hose incorporate a one-way check valve?
If not, you need to add one.
I found this out first hand: http://mx5cartalk.com/forum/viewtopic.php?f=57&t=41091&start=151&hilit=brake+booster
tescoking wrote:Lokiel wrote:Does your brake booster -> intake manifold hose incorporate a one-way check valve?
I think I don't have any problem for that right now, but there are some silicone hoses too small to fit.
I will post a picture later so that you know what hoses I have replaced.
The upper radiator hoses has to use FM specific one, and I am buying a longer red silicone hose for the overflow one.
tescoking wrote:I forgot to order the endlinks, so I will just get the endlinks from Racing Beat.
Lokiel wrote:tescoking wrote:Lokiel wrote:Does your brake booster -> intake manifold hose incorporate a one-way check valve?
Easy enough to check, just remove the top left hose:
... and blow through it from both ends - only one end should work.
The fact that the hose appears molded (ie. has bends) gives me some confidence that it may have a one-way valve incorporated but you do need to confirm this, otherwise your brake booster chamber is effectively increasing the volume of your intake manifold and you wont get the throttle response you expect.
Okibi wrote:tescoking wrote:I forgot to order the endlinks, so I will just get the endlinks from Racing Beat.
Ian had a set from Racingbeat that didn't last long but that was probably 15 years ago, perhaps they've updated their design.
tescoking wrote::
If I can blow through both end, does that mean I will need a valve? Or something I will need to do with the hose?
