mrpham's summer build
mrpham
Re: mrpham's summer build
Postby mrpham » Fri Aug 17, 2012 7:05 pm
ITB Build Part 8 - http://omgpham.com/itb-build-part-8
Since the wiring tested perfectly, it was time for the interior to go back in =)
I replaced my crappy carpet with carpet from an NB, pretty much the same thing. I did have to cut some holes for the seat belt buckle because mine are bolted to the floor, I believe the NB buckles are attached to the seat rail hence no holes in the carpet. I would definitely recommend the NB carpet over the NA, it feels much nicer and usually found in better condition than older NA stuff.
Roll bar back in, super clean carpet =D
Super happy with how the flip-panel turned out, looks awesome and gives plenty of protection for the fuse/relay panel. And yes, the kiddie seat is gone now.
Current Forum Specials!
Dan
Postby Dan » Fri Aug 17, 2012 7:08 pm
You're the loom master and that's a very clean install, good job!
Postby Okibi » Fri Aug 17, 2012 7:47 pm
One of my favourite threads. :mrgreen:
mrpham
Postby mrpham » Mon Aug 20, 2012 7:10 pm
Some more progress over the weekend.
Kev05
Postby Kev05 » Mon Aug 20, 2012 7:12 pm
Looking very good there, John. Hope to see the complete work at the next Nebo gathering.
mrpham
Postby mrpham » Wed Aug 22, 2012 8:55 pm
So had a chat with wozzah aka Warren Heath Performance...
Since the camshafts I'm getting are "huge" and need to be dialed up with adjustable cam pulleys, I've decided to hand it over to someone qualified to dial them up. Once I get it back, I'll throw the engine back in and get it running. Then take it to the dyno tuner to finalise the cam settings.
I've made a list of workshops to get a quote, but greatly appreciated if anyone can make further recommendations too.
So far:
  • Chilton Engineering
  • Torque Team
  • NA Autosports
  • GLS Engineering
I would normally give it a try myself, but the new camshafts make the engine "interference" type so I really don't want to screw anything up.
Postby Magpie » Wed Aug 22, 2012 9:10 pm
What are the specs of the cams?
mrpham
Postby mrpham » Wed Aug 22, 2012 9:18 pm
Magpie wrote:What are the specs of the cams?
These are the current two options, final choice will be up to Warren.
1. 240@50, 283adv, .407" lift (less lash)
2. 239@50, 280adv, .375" lift
Postby NitroDann » Wed Aug 22, 2012 9:28 pm
More duration similar lift to my old ones.
Expect torques out the wazoo!
mrpham
Postby mrpham » Wed Aug 22, 2012 9:41 pm
NitroDann wrote:More duration similar lift to my old ones.
Sounds awesome :D
After all this I have to make some decisions on gearbox and diff ratios.
Apu
Postby Apu » Wed Aug 22, 2012 9:43 pm
You'll love it!
mrpham
Postby mrpham » Thu Aug 23, 2012 8:48 pm
Installed the seat today, sat in it for a few minutes before. I wasn't going anywhere but it felt real nice :D
mrpham
Postby mrpham » Sat Aug 25, 2012 1:43 am
Decided to spoil myself and had a bid placed on this....
http://page11.auctions.yahoo.co.jp/jp/auction/n113497380
rxmx
Postby rxmx » Sat Aug 25, 2012 11:57 am
It's coming together nicely, looking forward to some sound clips when this thing is on song
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
slug_dub
Postby slug_dub » Sat Aug 25, 2012 12:20 pm
I've been eyeing off those KG Works pieces as well! I'll fight ya for it! Garn! I'll take ya!
Ahem.
Users browsing this forum: No registered users and 67 guests
