Nice work dude. Seriously wish i had the money/time/space/fab skills to do this sort of stuff.
Beelzeboss wrote:
NitroDann wrote:FFFFF YEAH !!
Hjt wrote:How did I miss this amount of framework when I came by with Eren :S anyways I must see the progress in person! Are you working on the car most afternoons Andrew?
plohl wrote:how'd you end up doing the suspension geometry? Did you just do 2D sketches to find your roll centers, camber change etc etc? It looks like the front roll centre is pretty high. Are you going to be using existing uprights or fabing your own? How much adjustability have you designed into it? (bulk pictures warrent bulk questions)
mitch_f1 wrote:Beelzeboss wrote:
I would like this in my garage please ;)
Seriously though, amazing work here, and I am SUPER jealous of all your equipment!! Cannot wait to see the final finished project!!
Beelzeboss wrote:Thanks Plohl, I'll try to answer all the questions but it was a while ago that I did all the design work.
I used a free program called WISHBONE.EXE and Solidworks to design the majority of the suspension.Wishbone calculates roll centres, camber change, bump steer, ackermann angle, castor, camber, steering axis inclination, etc. I read a few suspension books and just tried to get values that looked OK. Unfortunately due to the design of the uprights there is a lot of KPI, or steering axis inclination. I countered this by giving the system lots of castor angle. It should be a very light car so I hope the steering won't be too heavy, but all the camber curves look good.
The front roll centre looks high because the balljoint pivots aren't in the wishbones. If you look at the CAD picture you can see that a line drawn through the bottom pivots is dead horizontal at ride height (good) and the theoretical top arm (through the pivots) isn't as angled as it looks in the pics.
I designed the car to be built from a single donor, a 2002 Subaru Impreza RS, so I'm using the uprights from that. It requires a bracket to convert the uprights from macpherson strut to double wishbone and the geometry is not perfect. I'll just have to cross my fingers and hope it goes well. If I was to start it again I'd use MX-5 uprights instead, it would have simplified and improved the suspension no end.
The first wishbones will have very little adjustability built in, probably only camber, though I'll make them using a JIG so at a later date I can go back and make fully adjustable rose-jointed arms if I feel it's necessary.
Basically the car was designed to be a road car which looked like a le mans racer. I want it to be comfortable enough to use every day but still good on the race track. It should be fun on the track with its low weight and good power to weight ratio (hopefully less than 700kg and 180kw). I'm also using triple adjustable coilovers from a Yamaha R6 all round, rocker arm suspension up front, pushrods at the back and adjustable swaybars. That should allow me to fix any handling issues the car has from weird suspension setup, even though the camber curves and general behavior of the suspension looks alright in CAD.
plohl wrote:Thanks very much for the reply Andrew. Its sounds like you've done the best with what you have had to work with. Well done man, I know how long sort out suspension can take! It’s such a compromise!
Do you get much camber change in roll? I suppose you would get hardly any in bump. How much caster will you be running? As you said, it'll be pretty light and have nothing really at the front weigh it down; I agree it should be ok.
I have only worked with susprog, but from looking at wishbone.exe, it looks fairly similar. Now I just have to get it to work on 64bit!
Did you design much anti dive/ anti squat into the suspension? I know it can be very hard to judge the right amount.
dazzvazz wrote:Hey Andrew
Would you be able to fabricate a balanced plenum?
Dale
dazzvazz wrote:It's where the main inlet to the plenum is in the centre of the four outlets opposed to the main inlet entering from the side. Think of the R33 GTS-T plenum compared to the MX-5's. It helps with all cylinders getting the same rate of airflow, if I am correct with my logic.
NitroDann wrote:Exhaust fits nice.
What did you weld it with?
dazzvazz wrote:Beelzeboss wrote:dazzvazz wrote:It's where the main inlet to the plenum is in the centre of the four outlets opposed to the main inlet entering from the side. Think of the R33 GTS-T plenum compared to the MX-5's. It helps with all cylinders getting the same rate of airflow, if I am correct with my logic.
Ah OK, I get it now. Would there be enough room in an MX-5 engine bay for that type of manifold?
Yeah, should be plenty. Would also be beneficial to relocate the entire induction to the cold side to save re-routing the induction to the hot side.
No hot side or cold side with the V6, though.
plohl wrote:I have dosbox! didnt even think to use it.![]()
The engine looks pretty badass in the car!
Bizi wrote:Andrew, does Rhys or Emily have a manual steering rack in either of the NA6 cars they have in the Parts forum, selling bits?
viewtopic.php?f=44&t=51721
viewtopic.php?f=44&t=50821
Otherwise, Formaz, the wrecker of MX5s often on eBay?
May have a NA or NB and if an NB, possibly the brakes and maybe a TorSen.
They have a VVTI engine, complete for $1500 whhich seems to be a bargain and may have other stuff, if it helps.
http://www.ebay.com.au/sch/formaz34/m.h ... 4340.l2562
I can't recommend this person I have no idea what they have but the ad has been on gumtree sydney for a long time. Hope it helps.
http://www.gumtree.com.au/s-ad/yagoona/ ... /346901908
I'll post any sightings in case it helps, but if you have the gear, then update us.
Love the pics!
Jace wrote:good thing you painted those valve covers at the start!
Bizi wrote:When do you estimate you will start it? You should get a few people over - if you're confident. It will be special.
Once you get to that stage is it a case of getting it all engineered?
B.
