Stuart & Lisa's MINX
Charlie Brown
Re: Stuart & Lisa's MINX
Postby Charlie Brown » Wed Feb 01, 2012 8:13 am
Looks good Stu.
I picked a couple of points where your could pick up time.
Twice you reached down to adjust your balls. Once at the start of lap 1 and again in lap 2. :lol:
Next, why run with the top down? Must be worth a second a lap with it up.
MINX
Postby MINX » Wed Feb 01, 2012 8:48 am
Charlie Brown wrote:Looks good Stu.
Thanks CB
I am sure there are lots of ways to go faster. But I am gradually improving.
I WASNT ADJUSTING MY BALLS they normally shrink up and hide when i go on track!
I tend to reset the seat belt tension because i move around a bit on stock SE leather seat.
Hence also why the roof is down, I cant fit my fat head with a helmet on under the roof.
A Sparco might be on the shopping list this year.
MINX
Postby MINX » Wed Feb 01, 2012 8:56 am
Helmet height issue can be seen in these pics
(courtesy BitRusty)
Postby Lokiel » Wed Feb 01, 2012 9:07 am
I reckon your "sunroof in a hardtop" idea might be an option.
MINX
Postby MINX » Wed Feb 01, 2012 12:16 pm
New pressie from tire rack
For my spirited DD use
Yanks rave about them so I thought I would test a set
At 200utg they should suit my varied needs
MINX
Postby MINX » Tue Mar 27, 2012 6:43 am
Minx at Lakeside
26th March 2012
New PB 65.16 :D
Charlie Brown
Postby Charlie Brown » Tue Mar 27, 2012 9:02 am
Sh*t Stu you scared me, you must have been worried. :shock:
What did you do wrong? Grabbed 2nd instead of 4th or got off the clutch too quickly?
Hjt
Postby Hjt » Tue Mar 27, 2012 9:20 am
Great footage, as Charlie mentioned your roof down costs time but I'm tall and understand your issue. A fixed back,lower seat and a 5/6 point harness with roof up would give you a new edge!
MINX
Postby MINX » Tue Mar 27, 2012 9:44 am
CB - yes, i originally thought it spun because i outbraked myself and turned in while on the abs, but looking at the video it looks like i picked 2nd, which makes sense why it flicked so violently and much quicker than i could correct.
Approach speed to tha corner is 193kph for i guess, a 90kph cnr :shock:
HJT - yes, doesnt seem to matter how well i get onto the str8, i cant seem to crack higher than 193 on my scanguage
car seems to hit and aero brick wall - and i run out of str8 - a seat and harness - with roof up - would definitely see faster str8 speed and improved lap times.
Driver still has room for improvement - problem is teaching yourself has limitations- i really need some expert coaching to progress more.
I am reasonably happy with second fastest for the day from 34 drivers.
Hjt
Postby Hjt » Tue Mar 27, 2012 10:14 am
Great result!
You should give the star specs a track day. You will be surprised by there grip!
ASE05
Postby ASE05 » Tue Mar 27, 2012 10:37 am
Whoop, whoop, looking good mate!
Sing that song, puff all night long.......
Charlie Brown
Postby Charlie Brown » Tue Mar 27, 2012 12:49 pm
MINX wrote:CB - yes, i originally thought it spun because i outbraked myself and turned in while on the abs, but looking at the video it looks like i picked 2nd, which makes sense why it flicked so violently and much quicker than i could correct.
I just saw how much the gear stick kicked left & right after you took your hand off it and thought there's a lot of load on those gearbox mounts to get such a violent movement. So either 2nd or a clutch dump locking the rear wheels.
toppertee
Postby toppertee » Tue Mar 27, 2012 6:22 pm
Hi Stuart,
I'm 6'2, i've bolted a sparco with a custom bracket to the floor. Next time i'm around feel free to jump in and see how you like. You are more than weclome to pinch the key and take it around the track next club day and see how you go.
You won't have to worry about 193 down the main straight.
Joys of my NA6, no power steering, no a/c, no horse power, plus no grip as the tyres have gone off in a big way.
Mines the white one, with the red roof.
MINX
Postby MINX » Tue Mar 27, 2012 8:40 pm
Thanks TT,
yes Sparco is on shopping list this year.
Has to be removable for DD duties.
Anyone got a sparco 4sale ???
Hjt
Postby Hjt » Tue Mar 27, 2012 8:47 pm
red devil i think has a sparco "junior" or something similar for sale. It's an old sprint 5 design, metal frame not fibreglass.
