its beer oclock, ill do water pump in the morning, then its put back together time
the water pumps seems as though it has been leaking a tad. The front of the block it white
i shall be picking up a Cooling Pro radiator tomorrow also
broady wrote:Yeah, I'll bring a hammer and angle grinder, that'll fix it.
RawSouth wrote:broady wrote:Yeah, I'll bring a hammer and angle grinder, that'll fix it.
Nah, you only need duct tape and WD40.
If it moves, and it shouldn't, use duct tape. If it doesn't move, and it should, use WD40.
You can trust us Regie, we'll have her fixed in a jiffy
two40 wrote:I was just showing my colleague these pics. He just paid $1400 for a major service including new water pump. Pays to do it yourself if you can.
Hammer wrote:Love the Wrinkle paint on the engine cover.
Top job.
Regie wrote:10th June
Rear sway bar installed.. Makes the car a lot more flat. With my Koni's turned up full hard and both sway bars on the soft setting the car seems to be very tail happy. I will have to fiddle around with the settings.
