GSlender's Track Beeotch!
gslender
Re: GSlender's Track Beeotch!
Postby gslender » Tue Sep 02, 2014 4:16 pm
toppertee wrote:Nice......
You going to have a crack at alloy welding?
Nah, I doubt it... I'd need to have the tools for a while whilst I learn, and that's not something I'm that keen to do.
I've got someone keen to help machine cut the panels out of scrap aluminium, so I could just take that somewhere to have them weld it up.
I've seen some folks do solder / brazing of aluminium, and I could probably give that a go. Some reports indicate that these are as strong as welds and only performed with a heat source - less than 400 deg.
I'm also wondering about fibreglass or carbon, but my guess is that this will be more costly than aluminium.
Postby Magpie » Tue Sep 02, 2014 4:36 pm
You could make your balsa model, seal the wood and then use it to make a plug for carbon or fibreglass. The beauty of a plug is that you could make many copies and possibly sell to others... There is a lot of work needed to get the plug just right but it would be worth it.
I'm going to borrow your logic and see what I can do to make use of longer trumpets. Once I can source some suitable trumpets I will use balsa wood to fabricate the shape required.
gslender
Postby gslender » Wed Sep 03, 2014 10:13 am
Another option, if all others look too expensive or unlikely, is to fibre glass the balsa itself. Odd initially I know, but after looking into it, it would look like a solid and well finished product. I'd just have to be sure I've got the mounting areas and pipework stiff enough.
toppertee
Postby toppertee » Fri Sep 05, 2014 8:00 pm
I'm sure we could knock it up in the shed :wink: I'll fire the welder up and burn some holes in alloy
http://youtu.be/nqRVqXMyzhM
gslender
Postby gslender » Fri Sep 05, 2014 10:42 pm
I've got a sump that says that would be a bad idea
gslender
Postby gslender » Sat Sep 06, 2014 1:44 pm
Checked the valve clearances and boy, they are all out!
Looks like I'll need 16 new shims!!
Anyone got any recommendations on where to best buy some replacement shims?
G
rascal
Postby rascal » Sat Sep 06, 2014 2:13 pm
http://www.precisionshims.com.au/
Excellent to deal with, next day post, good prices..
toppertee
Postby toppertee » Sat Sep 06, 2014 6:55 pm
gslender wrote:I've got a sump that says that would be a bad idea
Still holds most it's oil :mrgreen:
gslender
Postby gslender » Mon Sep 08, 2014 8:22 am
Valve cover off.
Cams out.
Shims out.
gslender
Postby gslender » Mon Sep 08, 2014 8:27 am
Air box template finished.
toppertee
Postby toppertee » Mon Sep 08, 2014 12:40 pm
Two thumbs up :D
Dweezle
Postby Dweezle » Mon Sep 08, 2014 12:44 pm
Yeah really Impressive
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Postby Magpie » Mon Sep 08, 2014 1:14 pm
Nice, what is the plan? Fibreglass? You could use the box to make a mould?
Watching with interest!
gslender
Postby gslender » Mon Sep 08, 2014 1:25 pm
I'm talking with someone about milling the item from a solid billet. Single piece and hopefully fairly repeatable if the price is reasonable.
If that doesn't work, then looking at sheets cut to similar dimensions for welding etc.
Failing that, I will look at options for fibreglass or carbon fibre etc. hardest part with glass is how to make it with a lid etc. I need to chat with some folks who do this all the time etc.
Apu
Postby Apu » Tue Sep 09, 2014 9:29 am
What about 3D printing?
