finally got it through the grey matter on how to post the video................ thanks to stu. will do that later
today the weather only got to 12 degrees but good enough to prime - rub and top coat the rear end section and top and clear coat the boot.
primed rear end of the se yesterday. today it was rubbed back with 600 wet/dry sandpaper. let dry then wiped over with grease/wax remover
inside the boot was previously primed rubbed back ( again with 600 wet/dry) wiped with grease/wax remover and two top coats applied
two more coats were then applied and left to dry for 20 minutes. followed on by 3 or 4 top coats of clear.
here;s a good example of the shine ( gloss)
another shot of the boot
end results
probably a video following later on today.
