Renesis NC Track Car - In the Build - Updated 4 Jan 2009
Postby Okibi » Mon Jan 05, 2009 7:21 pm
IF they can build some that fit inside the stock 15s without a need for a spacer that use DBA rotors and light weight hats they'll be able to make bulk coin :mrgreen:
Fatty
Postby Fatty » Mon Jan 05, 2009 7:26 pm
Okibi wrote:IF they can build some that fit inside the stock 15s without a need for a spacer that use DBA rotors and light weight hats they'll be able to make bulk coin :mrgreen:
8)
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Mon Jan 05, 2009 10:36 pm
whats the plan for the rear brakes with those massive stoppers on the front? what size rotor are you going to use? also will the rotors be interchangable between iron and carbon :twisted:
Postby orx626 » Mon Jan 05, 2009 10:59 pm
graemebc wrote:Just read this thread from start to finish & :shock: "exceptional work" does not really come close!
What I like the best is the alloy welding from your other cars. Its so tricky to get it neat.
So very cool to watch this come together as its one man and his dream in a workshop not a squad of engineers.
Look forward to seeing the beast in person :D
Cheers Graeme! :D
Credit for the aluminium welding on all my vehicles must go to Richard and Drew from ARE (Aluminium Radiators and Engineering). Their skills in this area are certainly a cut above. 8) Their prowess will be called upon again before this project is complete.
I'm around the workshop most weekends, drop me a PM if you would like to pop in sometime.
Postby orx626 » Mon Jan 05, 2009 11:10 pm
16bit wrote:whats the plan for the rear brakes with those massive stoppers on the front?
Hi James, the rear brakes will be changed according to what the calculations tell me. It's a balance between the piston cross-sectional areas and the effective centreline radius of the pads. I have other smaller Brembos that may be the right size when coupled with the right rotor for the rear.
16bit wrote:what size rotor are you going to use?
I intend to use 2-piece 355 x 32mm discs....probably DBA 5000 series rotors with a yet to be determined custom offset aluminium hat. I might be lucky enough and find that DBA may have the right offset hat in their limited range.
16bit wrote:whats the plan for the rear brakes with those massive stoppers on the front? what size rotor are you going to use? also will the rotors be interchangable between iron and carbon :twisted:
I hadn't given consideration to carbon rotors...no idea of the cost either. If they are available with the same hat/rotor attachment detail as the 5000 series then it might be worth the look...although I don't think I'm going to have a problem with brake fade :lol: .
Postby Hammer » Tue Jan 06, 2009 12:07 am
orx626, have you been doing a video diary on this project? It would be cool to watch one day when you finally finish it.
Check out what a guy from Sweden did on his project car, a 240z.
Go to YouTube to view the video diaries. Search for "Hugo 240z". Your project reminds me of theirs.
mx52nv
Purple Porsche Eater
Postby mx52nv » Tue Jan 06, 2009 2:23 am
orx626 wrote:I intend to use 2-piece 355 x 32mm discs....
*Faints and hits head on floor with loud THUD!!*
16bit
Postby 16bit » Tue Jan 06, 2009 9:48 am
sounding like its going to brake quite violently - what pads are you going for? ds3000 plus? carbotech xp16?
Postby orx626 » Tue Jan 06, 2009 10:00 am
16bit wrote:sounding like its going to brake quite violently - what pads are you going for? ds3000 plus? carbotech xp16?
Just standard road going pads that came with the calipers James.
16bit
Postby 16bit » Tue Jan 06, 2009 6:20 pm
Alex
Postby Alex » Wed Jan 07, 2009 2:23 pm
Hammer wrote:orx626, have you been doing a video diary on this project? It would be cool to watch one day when you finally finish it.
http://forums.hybridz.org/showthread.php?t=106731 ??
Postby orx626 » Wed Jan 07, 2009 3:10 pm
I'm keen guys but not that keen! :P Have been keeping a pretty good photo history of the build...have taken almost 1000 photos of the build so far! :shock:
mazlot
Postby mazlot » Wed Jan 07, 2009 3:40 pm
Make sure you do take lots of photo's, so when you build mine you remember what to do :mrgreen:
Farken Gruven
Mokesta
Postby Mokesta » Wed Jan 07, 2009 8:55 pm
Looking professional as always.
Now for my selfish concern... That set of roof diagonals looks like it might be in the way of my head when I take your car out for a few laps. I am a bit taller than you and, what may clear your helmet might hit mine. :D I'm sure these are high on your list of priotities, just like making sure the seat has a f/r adjustability. :lol: How will you ever know that you are getting the most out of the car if you don't let me drive it??? So... a roof diagonal that starts at passneger side headrest and ends and drivers A-pillar would suit me better.
(or you can design up a VERY strong sh1t-grab handle for the passenger side and take me for a ride, because you know that one way or another I'm having a go in this car)
M
Postby orx626 » Wed Jan 07, 2009 10:30 pm
mazlot wrote:Make sure you do take lots of photo's, so when you build mine you remember what to do :mrgreen:
A road legal version would certainly be a noiice bit of gear! You never know where this project may lead Mazlot!
