SLOWMX5 --- Trying to make a slow MX5 fast---
- bruce
- Vehicle: NA8 - Turbo
Re: SLOWMX5 --- Trying to make a slow MX5 fast---
That's good news that the little T2 is hanging on.
- MX5NBpsi
- Vehicle: NB8B - Turbo
Last nights progress
- Coldside pipe done.
- started to mod the rocker cover with baffles and AN fittings for second tank
- SKYHI
Haven't seen this build thread before. Looks very neat, well done
- MX5NBpsi
Getting closer
Jobs finished
-Finished my coolant re-route i needed to dodge the plazmaman clamp
-Finished my valve cover all painted and sealed up
-Ported the manifold was close but every little bit counts
-Sorted out bolts for plenum spacer Skunk2's bolts are too short they dont work with the BP manifold
-Re-wired all my incabin gauges
-Tested rpm signal with the Haltech to check my wiring (got it to sweep to 8,000rpm when turned on )
Just waiting on a inlet manifold gasket and almost ready to tune it. i want to tune it get it to its happy power level and then the plance is to pull the Auto and have it checked and upgraded.
Jobs finished
- bruce
What time does it have to run before you are required to run a full cage, etc? Or do the Test'n'Tune events have no restrictions?
- MX5NBpsi
bruce wrote:What time does it have to run before you are required to run a full cage, etc? Or do the Test'n'Tune events have no restrictions?
For ADRA tracks (Calderpark for me )11.0 i think was my cut off but as it has the rollbar im trying to get a ticket to go 10.0 and if i run under that i just wont come back. As for Heathcote there is no rule just if the car looks safe you can run it down the tack .
- bruce
- MX5NBpsi
Motor all sealed up.
all i though i had left was 1 wire and Vac block hose to go but ive just learnt that i have a 12+1 trigger wheel not a 36-2 so im stuffed and i need to order a trigger wheel from the USA before i can do anything else.
- Daffy
MX5NBpsi wrote:Motor all sealed up.
I have a brand new one for Supermiata balancer that I can sell you sitting in my mechanic’s work shop that I can post Monday if you want- feel free to PM if your interested mate.
- ManiacLachy
- Engaged
Pretty sure that trigger wheel will only work with the SM damper, Daffy.
The Bartune one is local and should work with an OEM damper
https://www.mx5performance.com.au/collections/nb/products/36-2-tooth-timing-trigger-wheel-mazda-mx-5
- MX5NBpsi
ManiacLachy wrote:Pretty sure that trigger wheel will only work with the SM damper, Daffy.
i need a 4 tooth trigger after advice from Haltech due to the softwares internal formula and it needs to suit the supermiata damper they are different to the ATI and OEM Balancer.
- ManiacLachy
- Engaged
Ah cool. Didn't realise you had the SM as well.
- MX5NBpsi
Finally.
Felt like i was waiting forever
- MX5NBpsi
Finally running !!
I couldn’t get my head around why the car wouldn’t run turns out i wired the coils as 4-3-2-1 instead of 1-2-3-4 so backwards car runs like a dream probably smoother than ever Haltech FTW.
Our plan was to setup all cruising fuels and timing and do a base line run well its base is 28psi as i chose too small an external gate for a GTX style Turbo but run what you brung so we got fuels and everything else flat with minimal timing and rich fuels and then we hit a snag its spinning tyres on the roller dyno (partly my fault it’s still got MT Streets on) and its hitting harder than before only 2 psi but the new setup is working and Air temps is killer so we called it with a plan of going to a hub dyno in future.
its 20 rwkw less than my old setup with much richer fuels at 11.5 and 9 degrees less spark Which is a great start and the Tuner is saying its coming on harder and earlier which is going to be all due to Dann’s manifold cause it’s a larger rear housing and front compressor.
Lets throw 35psi at it and see what she does hopefully it holds together
So All great news
So All great news
- bruce
I like reading this build.
Wonder if you should document it all on video and try to make some $ on Youtooob?
