StuwieP wrote:
Don't suppose you would want an engine, gearbox and diff too?
Yeah, I might be interested.
StuwieP wrote:
StuwieP wrote:Thanks Magpie, I'm already writing my list
I think the biggest struggle will be getting the old ancillaries to work as before.
Pretty sure I've accounted for everything (Inc AC) except one wire, which ran from the heater to the ECU.
I just don't know why the heater system would talk to the ECU, and what it would do... If anyone can shed any light, I'd appreciate it.
greenMachine wrote:Air doesn't come on until the a/c switch is 'on', and fan is on at least setting 1 (ie not fan off) ... on an NB anyway.
StuwieP wrote:Looks to me as though it is activated when the fan is turned from low (1) to med (2) and stays on at H2 (3) and H1 (4).
Doesn't appear to interact with the AC unit at all - direct from fan to ECU.
The question is, is it a variable resistor? i.e. should I be running it to an AVI input rather than a DSI input on the haltech - so each step = more load on battery/alternator = compensate by adding revs?
