Dougs BRG V-Special Roadster
Doug Danger
Re: Dougs BRG V-Special Roadster
Postby Doug Danger » Mon Nov 18, 2013 1:53 pm
Ok. Minor update.
Exhaust went on last month, bilsteins with lowered springs went on too. So much better, feels alive again. Been on a few cruises, some with mates, some with the mazda car club. Still enjoying the car immensely.
Here are a few more happy snaps for the photo diary. Needs a wash :P
Postby hks_kansei » Mon Nov 18, 2013 1:56 pm
Driving down Chesterville road over the weekend?
I spotted a BRG with some dishy wheels heading along there.
Doug Danger
Postby Doug Danger » Mon Nov 18, 2013 2:49 pm
Yep that would've been me :)
Dehamsta
Postby Dehamsta » Mon Nov 18, 2013 10:44 pm
In case u don't know, your wheels are sprint hart cp's. Jdm wheels! I know coz I have a set.
Doug Danger
Postby Doug Danger » Tue Nov 19, 2013 11:37 am
Oh wow, thanks! I had no idea what they were. All I knew about them was there was a sticker branding them 'Dunlop MotorSport Sprints'. No one knew what they were and no info anywhere. Cheers :)
Doug Danger
Postby Doug Danger » Mon Dec 02, 2013 7:43 pm
Bad news :(. After getting the car ready for the track, sorting out suspension and getting a loctite fix on the crank, the issue has come back, being detrimental to crank, key and resulted in sh*t bouncing around and causing heaps of damage.
A new engine is needed. Contemplating an na8 engine or nb8a. Not sure whether I want to pay the labour for a 1.6 when for a little more I can get a 1.8. Anyway. Massive hole in the wallet.
Doug Danger
Postby Doug Danger » Fri Dec 20, 2013 5:36 pm
Got the car back yesterday!
Ended up getting a long nose low kms b6 in. Also, new clutch and flywheel as well as some other maintenance has been done.
Have spent a lot of money and was contemplating selling but just having it back and being able to drive it again makes it all worth it. Image
speed freak
Postby speed freak » Fri Dec 20, 2013 5:49 pm
Doug Danger wrote:Got the car back yesterday!
Good to hear :) It sucks having to spend the money but like you said its well worth it when your back behind the wheel and enjoying the drive again then the dollar factor just goes out the window.
Doug Danger
Postby Doug Danger » Fri Mar 21, 2014 4:36 pm
It's been a while since my last update, a lot has happened.
The car still has its niggly issues however I've learned to live with them and just enjoy the car. Quite honestly it has been driving like a dream, taking it out for regular hill drives and taken it to Winton twice since my last update. The car's temp gauge still does move 3/4 high on freeway driving but only on cold days. On hot days or when the car has been dríven hard it doesn't move at all.
I think it has to do with the coolant temp at which the thermostat opens, due to the fact that that when it happens all I need to do is push it a little harder (slowing to 80 on the freeway and hard accel to 130) to get the temp hot enough to open it up. When its being pushed or its hot outside the temps rise more rapidly ensuring the thermostat opens with the rising temps. Other wise it will slowly climb and rest on the 3/4 mark. Either way, it hasn't affected anything in the way of drivability, doesn't feel any different.
As my previous posts state, every single thing has been done to ensure adequate cooling, from replacing the radiator 3 times, new coolant and heater hoses, new water pump, new fan switch, 2 new thermostats, new temp sensors all round, new clusters, new temp gauges and readers within the clusters and more I'm probably forgetting.
So I'm pretty confident that the cooling system is ok.
Here are a few happy snaps I took the other day. ImageImageImage
And also in other news I bought an FD Series 7 that I'm utterly in love with and a banged up Soarer that I'm using as a project ImageImageImage
kazama
Postby kazama » Fri Mar 21, 2014 5:00 pm
love the new wheels
love rx7s
& i also love soarers
good taste my friend
Nevyn72
Postby Nevyn72 » Fri Mar 21, 2014 9:38 pm
Just a thought on the cooling issue, you could possibly try one of these.....
http://www.maruhamotors.co.jp/miata/par ... ensor.html
or the thermostat by itself.
http://www.maruhamotors.co.jp/miata/par ... ostat.html
Whichever applies to your motor.
Doug Danger
Postby Doug Danger » Tue Mar 25, 2014 3:21 pm
Thanks Kazama, the wheels are the same just sprayed white actually though. I'm glad others like them too though :).
Nevyn, thanks for the links, will suss them out!
Doug Danger
Postby Doug Danger » Wed Apr 16, 2014 9:14 pm
Have collected some seats, they're not the same but doesn't really both me. Now to get the cats off, get some rails and whack them in!Image
Doug Danger
Postby Doug Danger » Wed Apr 16, 2014 9:16 pm
Another happy snap of my babies!
Doug Danger
Postby Doug Danger » Wed Apr 16, 2014 9:17 pm
