my silver nb buzz box
davekmoore
Re: my silver nb buzz box
Postby davekmoore » Wed Aug 07, 2013 8:13 pm
mmx005 wrote:
The tow bar adds great protection/ payback when you get rear ended, it is heavy tho :P
Great build. Do you realise the towbar stops the rear crumple zone reducing your injuries in a rear ender?
mmx005
Postby mmx005 » Thu Aug 08, 2013 2:56 pm
Thank you for the kind words Dave, it's nice to see someone is looking at my build. :-)
As for the tow bar, I hadnt really thought of it like that but you do raise a fair and valid point. Wouldn't the same be true for every car on the road with a towbar??
mmx005
Postby mmx005 » Thu Aug 08, 2013 11:17 pm
I knew my brake disc's were getting some ripples and a lip around the outside. I had been keeping an eye on it but it was getting serious and they were becoming quite thin. so it was about time to consider my options and replace them. Considering they were original from 98 and i purchased the car in 04, they had lasted pretty well with the abuse i had given them over the previous 8 years up to may 2012. :P
Given that i drive mostly street with a spirited/ track drive here and there, these were my options.
stock
cheap/easy to obtain disc's and pads to match, perfect for the street but how long would they last especially with my current power and future improvements???
slotted/slotted + drill,
within realistic realms of affordability, easy to obtain disc's and pads to match, has a little bit of "look at me" without being too out there, should be pretty easy to live with day to day in traffic etc, better performance, but had concernes as i'd heard that drilled brakes were prone to cracking/shattering under extreme temps/conditions (ie heavy track use etc) unless they are cast like porschse and other exotics disc's are.
big brake kit, (bbk)
at $1.3k for the cheap stuff and way beyond for the good/GREAT setups its a pretty expensive option for fixing the fronts but what to do about the rears??? then there is fitment issues, will they fit under my 15's, will they fit if i change my offset etc etc, which pads do i get?? how hard are they to obtain?? are they heavy?? the list of questions goes on and on and on!!!!! cold braking performance.
BBK'S are great for the turbo and track boys but im an N/A (some say girly :P ) daily dríven (like its stolen :mrgreen: ) kinda guy.
All of this did laps in my head for a while, gave me a headache. :lol:
Result, 4 new slot+drill with new bendix ultimate all round.
Nice,shiney and stops exceptionally well :mrgreen:
davekmoore
Postby davekmoore » Thu Aug 08, 2013 11:38 pm
mmx005 wrote:Thank you for the kind words Dave, it's nice to see someone is looking at my build. :-)
I do have a soft spot for sorted silver NBs.
mmx005 wrote:As for the tow bar, I hadnt really thought of it like that but you do raise a fair and valid point. Wouldn't the same be true for every car on the road with a towbar??
Yes. Low speed rear-enders will produce more whiplash. Higher speeds will increase the chance of worse injuries. Any rear-ender into a car with a towbar stands more of a chance of more severe damage to both cars and all the passengers including causing the thing that was dramatised on Offspring last night.
